frankando12
I have been using two of these 3 way adaptor's. This shows the original set up with the Central station before I tried connecting the Booster . The two bottom two leads are to the Central Station and the Feed from the Feedback Decoder the top lead comes from the Piko R/C sender unit. This system works fine with R/C except sometimes running several trains the Central Station Trips Out witch I think means it is Overloaded. That's the reason I had decided to add the Booster. The bottom photo shows the added 3 way Adaptor. with the added 6 wire cable connected to the Central Station and another 6 wire cable connected to the Booster . The top cable of the first photo go's the R/C Sender . The top cable of the bottom photo is the Cable that was connected to the Central Station Originally . I know this may seem complicated but this set up works when I tether the Navigator to the R/C sender Cable. Thanks for your interest and input.
