jameshilton
Well last week I muted that I was planning on bashing my Piko VT98 railbus (http://www.gscalecentral.net/Serbian-VT98-Piko-railbus-photos-m224509 ) and shared some photos of prototypes in use in Serbia.
The Piko model is a standard gauge prototype - but size wise it sits happily alongside my other LGB Austrian outline narrow gauge stock.
I've always been unhappy with the double buffers, promising myself that one day I'd do something - perhaps moving them up (to be the right height for a standard gauge wagon on roll-bockes) and adding a central buffer, or removing them altogether. I even contemplated just rebranding the excellent maroon finish with some EJ&KLR logos at one point...
However, finding the photos of the Serbian examples got me thinking again about starting this project sooner rather than later - coinciding with a desire to light the station and engine shed and run a train at dusk - the VT98 will be very easy to add internal lighting as it is pre-wired for the purpose with a wire up through the toilet compartment so you can fit one in the roof.
So - a rough outline of my plans...
- remove the double buffers
- remove the dodgy coupling and hose mouldings
- plate over the buffer holes
- add a central buffer
- add handrails to the doors
- fit interior lighting
- repaint and decal (it will be silver with a blue solebar - interesting article here on spraying silver with Humbrol enamels: http://www.ipmsstockholm.org/magazine/2005/12/stuff_eng_tech_nmf.htm )
- weather lightly (exhaust staining on roof and road grime on underframe)
So this thread will not document the inspiration (again - please look here: http://www.gscalecentral.net/Serbian-VT98-Piko-railbus-photos-m224509 ) but the build which will progress at a typical James pace of stop start on and off amongst a myriad of other large scale projects on my workbench.
Work started by stripping the railbus down to it's consitiuent parts - simply removing all the screws - the only troublesome one was behind a buffer so I had to snap the clip off the chassis but as I won't be re-using the buffer mounts I'm less worried about this...
I then used a razor saw to cleanly remove the buffer shanks, and then also the central 'fake' coupling moulding. The socket covers were sliced off from behind and the cuts then cleaned up with a craft knife/scapel with a chisel blade and a needle file.
