DafyddElvy
Do you know anyone living out of town who might have kerosene delivered for fuel oil.Thanks for the information. it's more difficult to find!!!
Its difficult to see, are you using the Proxxon purely as a drill or as a mill machine?Hello! I have recently bought in second hand a Proxxon F70 to drill and cut trough 6 (2x3) Mms of aluminium. I have still a lot to learn, but it works pretty good and ,with petrol lubricant, straight and fine.
a K-27 Mikado from Baldwin is on the bench.
View attachment 290438View attachment 290439
I Use the both fonctions with a drill Proxxon N° 28 761 " Multi purpose tungsten carbide miller" . I have 1 & 2 & 3 Millimètres miller. When I began, I tried to drill some holes with a Simple Pillar drill and then cut with the miller from hole to hole.Its difficult to see, are you using the Proxxon purely as a drill or as a mill machine?
Phil, liquid paraffin is not the same as paraffin used in heaters.For the small amount you use..
A bottle of Liquid Paraffin, from a Pharmacy, should suffice?
Use whiskey if you must, but never a good whisky, that's a punishable crime.Just have a look on this address: Your favorite aluminium milling/drilling lubricant? - Page 1
You can try every liquid except plain water and I add: good whisky!!
I hate whisky and I think that it is an abomination. I feel that it is my lifelong task to drink as much of it as I can, so that no other poor souls have to.Use whiskey if you must, but never a good whisky, that's a punishable crime.
My car is a gazolin motor ( 2 liters, 180 HP) and there is no problem to find "petrol" in France, even if some people try to militate the use. GérardI saw in another post that there was a limitation on purchasing automotive fuel (we call gasoline).... is there some sort of rationing going on there?
Sort of. Allegedly stocks are adequate but there are delivery problems. This has resulted in increased demand at the petrol stations so they run out faster.I saw in another post that there was a limitation on purchasing automotive fuel (we call gasoline).... is there some sort of rationing going on there?
The press mentioned that a couple of BP petrol stations had run out of fuel, this made a few idiots panic, which had the obvious domino effect. Now we all have to queue. It's very odd, but this crisis doesn't seemed to have lessened the amount of traffic.I saw in another post that there was a limitation on purchasing automotive fuel (we call gasoline).... is there some sort of rationing going on there?
Casey, don't misunderstand me, I have a Dremel and think it is great (especially after a cheap alternative I had), but it can be limiting with a 3mm maximum chuck size.My Dremel 220 Work Station:-
With Dremel 6200 fitted.
It certainly is a limiting factor Jimmy. But I find that for most of my modelling it does the job. I wouldn’t be without my Dremels.Casey, don't misunderstand me, I have a Dremel and think it is great (especially after a cheap alternative I had), but it can be limiting with a 3mm maximum chuck size.
Oh, certainly agree with that, mine is the 395 multipro, and I have had it over 15 years now, must be getting ready for an upgrade soon, a hint to Mrs B.I wouldn’t be without my Dremels.
