Martino
Very impressive. Rather more extensive that I had in mind!
Good idea! In the Good Old Days, we used to have to visit an old lady who wanted a garden, the fact she lived halfway up a 24 storey tower block didn't bother her, she just bought the soil and plants etc, and built on inside her flat ( no railway, unfortunately). The council went potty, as the damp dirt wrecked the place!Why not re-build the South Bucks in the basement?
It seems to be large enough for a sizeable 16mm layout....
something like this
Jackpot...you dont want anything else
poor Igor! now you really put your foot in it.He is and i am a carpenter by trade for decades....
being a continental like you, in none of the languages i speak, i would be able to name the type of connection, i believe you meant.make a cactus rack out of it ( Letterbak in het Nederlands...korm kormsen help wanted, please, sheets that can be slotted together in English)
and please skip hardboard and take advice of two old fashioned (real) carpenters...
Got the same problem here but as mine is set in a mountainous area steep grades come with the territory.it was (an unfinished) two level layout.
main problem were the longer than 13 yard ramps co connect the two layers. (grade of 6%)
They look very solid you should have no trouble thenIn the words of Blue Peter, here’s one I made earlier…. These are some racking units I made for the basement, purely for storage. I think what I intend to do is to create a similar construction however they will only be up to the first deck. This will allow storage underneath. Instead of being narrow, as these are, they will be 3 ft wide. The hardboard will be affixed to the top. I don’t require multiple levels of track. No hills etc. I am comfortable with this level of woodworking. I’ll work out the track plan on the floor, using actual track, to make sure it works. Then build the staging and build the layout ‘proper’. Running battery power with r/c, I don’t have to worry about wiring etc. That’s a good thing ;-)
View attachment 334022View attachment 334023
Yes, but just think about all the extra cleaning that goes with itI do envy the amount of indoor space which US homes generally provide
I have a plan. A cunning plan.Are you going to cover that fibreglass insulation?
What a great space , very much look forward to seeing your railway evolve.Found my points/switches today. Started laying out track plan on the floor of the ‘railway room’. Next step will be to actually cut and fit everything together. That will be the proof on concept and see if it all works in the real world. After that will be down to constructing the staging.
As you can see from the photos, it will be a terminus (Farnham Common) with attached engine shed and yard. Turntable in the far distance, Goods shed, not sure exactly where. The line will curve off in the distance and trough into the next ‘room’ where there will be the storage/fiddle yard.
I’ll have to start a new South Buckinghamshire Light Railway thread…..View attachment 334063View attachment 334064View attachment 334065
At the moment I’m planning on getting the Swift Sixteen turntable if it’s still available.That looks good.
I'm interested in how you will make the turntable as I need one for my indoor section.
Jim, a friend of mine in the FGRS (Florida), built a decent size 3-level indoor layout, in an industrial condo with a/c.I can see the wisdom of 3 x 1 framing and 3/8th ply. That sounds sensible.
