Tonights episode:
Slowing it down to shunting speed
Well I successfully got no2 apart so it was off to a clever mate to see about reducing the top speed.
We looked at the wiring and established that the motors are fed from the circuit board by the battery cartridge so this is where we were going to install the diode matrix.
We measured the voltage at the four different speeds and came out to
step1 3V
step2 4v
step3 5v
step4 6v
we decided to try roughly halving the voltage so Kev made a diode bridge up in a choc block and the test rig is seen below. This uses 1amp diodes, 3 in each direction so it works in both directions. It's incredibly simple if you can wield a soldering iron as there are no temperature sensitve components
Any way here's the rather bulky test unit in place. Note there are three cables running along the chassis a 6 way ribbon, a 3 way ribbon and a 2 way one, we want to cut just one wire of the 2 way one as seen in the picture and insert the diodes in this supply.
The finished article will hide them in the channel, if you used a block like this you'd need to hide it in the bonnet next to the battery compartment.
an overall shot with the circuit diagram show with an alternative manual change switch included to set the number of diodes to give alternative speeds for different running sessions.
Just for interest the location of the 16 clips holding the body on.
and the led lights
