Playmobil engine reverses itself while running!!
FatherMcD
13 Mar 2014
388
35
Idaho
United-States
I just took my Playmobil Express out of (cold) storage for a grandchild to run. Batteries were dead so both engine and tx batteries were replaced with good batteries. It started off fine but after a few feet stuttered and then reversed! After fiddling a bit it seems to run better at higher speeds but still stutters and occasionally reverses at lower speeds. Has anyone seen this behavior before or have any idea what is causing it? Also, I can't get to Walt's playmobil site. Is it gone?
-bbbb
21 Dec 2017
589
129
Idaho
Sounds like you are running a 27 MHZ RC train with interference. Metal objects like chairs, tables, brass track, etc. can cause interference. Also, other 27MHZ devices at a similar band can interfere with the control. Those RC trains were designed to run on plastic track, ideally away from interference. The positioning and angle of your controller and of your track can make a difference.
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
www.tumble-down-falls.co.uk
Walt passed away last year, I would assume the website, when with him.
5,010
76
The dreaded 27Mhz Rc is extremely fickle, commonly known as the ‘rusty boot effect’ back in the day when we were trying to run Live Steam from 27Mhz equipment. As -bbbb -bbbb says all of those things plus I wonder if these days WiFi, Mobile Phones and most certainly any CB Radio near you will affect things.
3,553
Could also be a broken aerial..
1,715
I've already written about the horrors of a loco suddenly reversing out of a tunnel
