Neil Robinson said:Another thing you may wish to consider is the weight. A lead acid installation is often heavier, this could be an advantage if mounted in a loco and more tractive effort is required but may have an adverse effect run time. If in a trailing car then the extra weight is usually bad news.whatlep said:Regarding the sealed lead acid cells, Tony's words are very helpful. It's easy enough in UK to get 12v 3.4mAh lead-acid cells which are cheaper than the equivalent AA cells and - obviously - have a longer nominal run time, but I will have to think about the voltage implications before taking further action. This battery stuff isn't as simple as I expected!![]()
The cards are covered in clear shrink wrap. Stops shorts etc.MR SPOCK said:That is really neat ,never thought about using plasticbags for the cards but its so simple and good to keep everything dry and insulated, the whole install looks very well thought out as well its given me some really good ideas, thanks
Doug said:When i built my boxcab diesel i used 4300mAh SubC NiMh batteries, with 9 cells giving 10.5 volts. They cost about £50 for a made up battery pack. They last for about 4 hours running the USA Trains powerblock. The speed controller cost about £60, the sound card £90, plus the cost of the R/C Tx and Rx.
Madman said:Doug said:When i built my boxcab diesel i used 4300mAh SubC NiMh batteries, with 9 cells giving 10.5 volts. They cost about £50 for a made up battery pack. They last for about 4 hours running the USA Trains powerblock. The speed controller cost about £60, the sound card £90, plus the cost of the R/C Tx and Rx.
Doug, that's are very nice box cab indeed. I see a skate sticking out of the bottom between the wheels. Did you use an LGB motor block. The chassis looks something like a Hartland chassis, is it? Again, I really like it.
Tony Walsham said:Personally I don't think wrapping electronics that can get hot in any sort of wrap is a good idea.
Granted the FET's may not get hot but voltage regulators usually do. Hot enough to melt plastic touching them.
I would mount the ESC's and sound card on a suitably sized sheet of thin styrene with a non metallic Silicone adhesive if you are worried about shorts. Leave the topside components free to the open air to aid cooling.
