bobg
Problems on the Trent Valley Branch Line.[/size]
[/b]
Problem 1.
There was no track![/size]
[/font]
Problem 2
The garden isn?t big enough. (Isn?t that everybody?s problem?)
I can?t do anything about that, they?ve stopped making land, especially round here, but the first one, well why not? Just a question of which gauge, 7 ¼? was certainly out of the question.
Problem 3
A large part of the usable garden area is taken up by a RAILWAY EMBANKMENT! Since when was that a problem for a railway? Since it was about 5 feet high!
I like to see proper trains, with plenty of stock behind, so I had to be careful about the ruling gradient on the line and after several abortive attempts had to settle for 1:40 max. Starting at the highest point (and furthest away) and using a string-line, I set that angle. At the nearest point to the house it was still around 3ft off the ground. That rather precludes the idea of a full loop, so new ?drawing board?; that old one doesn?t work! The min. radius was to be a generous 4ft due to the rolling stock.
Construction started. The terminus would not be much use on a 1:40 slope so the house end had to be raised to 4ft to allow for a level 15ft passing loop. Unfortunately this is a trifle high for a ?little person?, but then he?ll grow; in the meantime he?ll use a set of steps.
Sorry! All these inches, foots and yards! For you young uns, it?s an ?old fashioned type of measurement system, in vogue when the Romans was ?ere, and when the size of Standard Gauge was set. (If you don?t know??.ask and I?ll maybe explain later).
The method at this point was to make some sturdy steel brackets (probably too sturdy), screwed to the fence posts and mount 13in wide by 19mm OSB, with roofing-lath under-edges, glued and screwed for stiffness. The topping is ?torch-on? mineral roofing-felt, folded down the sides and trimmed off. The joints are carefully butted, not overlapped. The single line section is reduced to 7ins wide; this is also the point where the 1:40 kicks in.
Everything went swimmingly till I ran out of fence???..!!! Unfortunately this is not just the end of the fence, the boundary also turns to the right, 90deg, for 3ft 7ins and then turns back again to a 9 foot high hedge that?ll still need cuttin?.
Next problem! (No 5 or 6, I?ve lost count)
Solution, reverse curve, minimum radius to keep tight-ish to the boundary. Plotting an ?S? curve on flat ground, no problem. Plotting it on uneven sloping ground; problem. Plotting it three feet up, in mid air, over uneven sloping ground, with a 1:40 grade, huge problem! Being ?metal smart? I decided on a steel ladder system for support, and accurately(?) drew the curves out on some flat concrete.
The resulting ?frame? was then clamped to the end of the ?shelf? and the centres for the poles (scaffold) dropped with a plum-bob (Another Roman tool). The poles are just hammered in; to a depth of about 14ins, deep enough to make them stable once the whole thing is bolted together.
The steel ladder method continued until it met the slope of the old embankment. The grade continues right to the top and round the 6ft radius turn along to the top fence.
[/b]
Problem 1.
[/font]
Problem 2
Problem 3
