Stainzmeister said:Its a great looking loco.
It would be complete with a realistic looking driver figure standing on the footplate - perhaps one that could be fitted by the loco's owner as an option.
Personaly, if I get the odd loco with a problem, I like to solve the problem myself where possible. Postage is dear now, and once I get a loco in my sticky mitts, the thought of having to send it somewhere after I have just got it does not sit well.
PaulRhB said:Busybodies had figures out ready for the releasethere are also appropriate wagons available from IP engineering. They have identified that the problem on this loco arose from designing it to take after market draincocks due to customer demand which requires tighter tolerance on the piston setup.
That's just created a little problem with their piston setup it's not the fault of the after market parts and easy to check in production now they're aware of it.
As the majority of the batch were ok including the test samples it wasn't noticed and can't be seen by quick visual checking. The other issue with bent parts on a few with inadequate packing has already seen Accucraft order replacements from the factory.
If they do an electric version the wallet may be in trouble.
Edit: clarified the problem, hopefully![]()
Hi Mike, indeed they are, I emailled you about the coaches you mentioned on the SE Lounge and your email in your sig on there having an extra leterMr ACME said:For information, 7/8" scale rolling stock is available from other sources, including myself at http://WWW.ACMESTEAM.CO.UK. < Link To WWW.ACMESTEAM.CO.UK. I make two types of slate wagon and a Penrhyn open workmens' coach, both very keenly priced.
StephH said:I think its very harsh to criticize Accucraft on this at all, its a problem no-one has ever encountered before with one of these locomotives.
casey jones snr said:Another great video Chris. Accucraft seem to have sorted out the problem. Well done them.
