D
Deleted member 3553
Guest
hi again GAP...the unit is working as it should with an on/off switch between the two wires that normally go to the Gizmo...but only forward.......Mal R.
This is all there is to the Rx....as I understand it this Gizmo I messed up directs pulses to the rx to move loco forward or reverse........
Thanks GAP..........does this Tx control lever self return or can you set it at a given speed ? Like your advice....I can probably buy another car for about $30 but would be better to use your idea.......I messed up existing set up because I was trying fit a knob control to do away with holding the trigger....Without seeing it up close and personal I'll suggest that the ESC is mounted on that board possibly a H Bridge comprised of the transistors on the LHS.
Rather than hunt around, personally I would buy one of these to replace the controller and receiver.
HobbyKing 2.4Ghz 4Ch Tx & Rx V2 (Mode 2)
And use something like this to control the motor HobbyKing X-Car 45A Brushed Car ESC
From the picture it looks like you could fit the RX and ESC inside the loco.
Or, from the same place he can buy a new transmitter and receiver that looks the same as his original one..
Thanks Greg but I think I'll go with GAP's..........I suspect you really need an ESC with these trigger set ups to give you a smoother run ?????
No not necessarily Greg...more of the old waste not want not....the cars were wrecked and I thought i would try to use the RC on a couple of bashed up locos...Absolutely, I would not use the toy car controller myself, but since you were trying to repair the device I thought price was the priority.
Thanks....still in my PJ's.........planning a track alteration today so will have to move.and will follow up your post later in the day...Regards Mal.RI am using these ESCs in combination with the TX/RX from Hobbyking more and more as I do conversions.
Pololu Simple Motor Controller 18v7 (Fully Assembled)
I find them the easiest to use via a simple free computer program and a programming cable, you can set the centre position of the stick to be neutral ie off with FWD and REV at extreme ends of the stick movement or you can let the ESC self calibrate ie when switched on the position of the stick becomes neutral. There are other combinations for stick position that are explained in the user guide which is written in plain simple English. Run an eye over this to see if it suits your needs
Pololu Simple Motor Controller User’s Guide
Disclaimer; I have no commercial interest in the product or the supplier I just like them.
I like to have the stick position in a position that lets me have more FWD steps than REV working on the assumption that you do not go flat out in REV.
The other method that I use is this one from Sandstone and Termite, it does consume more space but the directions are easy to followed, in fact my neighbour who has no electrical knowledge at all got his trains running using it.
Sandstone & Termite Railway-2.4GHz RC
From the picture it looks like you could fit the RX and ESC inside the loco.[/
Harking back GAP........with this ESC (above) do you need to fit a servo and switch to activate reverse ??? And using Sandstone & Termite set up where is the servo/switch mounted ??? Thanks...Mardy.
Thank you GAP......will probably try out that ESC......with another TX I have..........I have repaired the Tx with the damaged "Gismo"...........found another one in a pile of bits and pieces I salvaged from the Grandees...now have two older loco's running off the one Tx.I have not used one of those ESCs but looking at the operation I guess it has FWD and REV built in so no servo/switch required.
On the S&T setup the switch is glued to the servo and that is put anywhere it will fit as long as the wires to the RX reach. All the components can be spread around the loco
Hi again GAP...your info paid off........found an ESC as you suggested above and although fitted very roughly to start, is working perfectly forward and reverse........the Tx has a certain range of acceleration on the trigger but also has a 3 position switch which ups the volt's apparently.......have no instructions on Tx or ESC but nothing bombed out yet........will tidy all up tomorrow with any luck and tick another problem...Thanks again for all the help....Mardy.I have not used one of those ESCs but looking at the operation I guess it has FWD and REV built in so no servo/switch required.
GoolRC TG3 2.4GHz 3CH Transmitter with Receiver for RC Car Boat Z5K1 and Hobby King X-car 45A brushed car ESC'........Glad to hear that it all works. Which ESC and Transmitter are you using?
Batt pack 8 x 1.2 NIMH...........GoolRC TG3 2.4GHz 3CH Transmitter with Receiver for RC Car Boat Z5K1 and Hobby King X-car 45A brushed car ESC'........
