Neil Robinson
I purchased one of these a couple of weeks ago and initially thought it to be suspect for the following reasons.
1/ It didn't work
2/ The baseplate had the model number 35015 molded on rather than 35010
3/The red and green stop and reset buttons were reversed. A green stop button, really !
To me this suggested someone had dismantled it and was somewhat careless with the reassembly so I returned it.
The helpful dealer checked his stock and commented "I have checked the replacement and this also has the same base as the 1 returned and have been told is normal as just a generic base plate."
A little research revealed that, whilst my two to three year old example worked O.K. on either AC or linear DC supplies, the latest version needs a switched mode DC supply.
As the replacement of my recent purchase was identical to the one I returned I decided to use it on a switched mode DC supply, ignore the incorrect model number on the base and dismantle the unit to swap the red and green buttons over myself.
It appears that Piko's supplier have some quality control issues.
1/ It didn't work
