Just to add my 2d worth - without trying to prolong the controversy ....Glad you raised the rainwater issue again Jimmy, I have worries about this on reflection. Acidity in the rain may not be the best thing to introduce to live steam. For my part I reckon having expended near or in many cases well over a grand UK for a live steam engine getting the right water should be a priority. A dehumidifier is really the only option to be sure, chemists so called de humidified has doubtful properties and certainly any tapwater may have chalk or other chemicals to keep it drinkable even in a soft water area.
Ok interesting, but can you say why water from a Dehumidifier needs to be filtered please?Just to add my 2d worth - without trying to prolong the controversy ....
Distilled water - changes it's ph from the moment it's made by the adsorption of CO2 if exposed to the atmosphere.
Dehumidifier water - needs filtration and can be acidic.
Rainwater - needs filtration and can be acidic, especially if the wind has been blowing from the industrial areas of N. europe.
Tumble dryer - can have lint - needs filtration.
Tap water - even soft water can cause eventual scaling.
Fridge water - needs filtration.
Sea water - causes dezincification and scaling - (just kidding ....)
So that leaves - with the best balance of pros and cons and convienience ....
Deionized water - with 5% tap water added to quench it's insatiable desire to claw back it's lost ions.
For the sake of an extra few minutes and a coffee filter, it's probably worth itThese contaminants in the water are of no consequence if you are using the device as a dehumidifier, in fact their removal has the benefit of improving the quality of the dried air - but if you want to use the waste water then you might want to consider filtering it.
Well, over this side of the pond we can get "steam distilled water" in (US) gallon jugs for $1 in the local supermarket. Can't beat that for convenience. (Why don't they sell them in the UK? The water is used for steam irons, etc.)So that leaves - with the best balance of pros and cons and convienience ....
First, I always filter my water what ever the source. Second deionised water I was told is a big No No, as the chemistry causes the ionisation in the vessel to deionise to match the contents eventually weakening the structure.Just to add my 2d worth - without trying to prolong the controversy ....
See the last line of my post #43 above ....................... Second deionised water I was told is a big No No, as the chemistry causes the ionisation in the vessel to deionise to match the contents eventually weakening the structure.
I thought it was de-ionised water that needed 5% tapwater, not distilled?distilled with 5 % tap water
Only Regner wants you to add tap-water, as they use brass for the boiler. Distilled water is preferred over de-ionized water in any steamer.I thought it was de-ionised water that needed 5% tapwater, not distilled?
I think you may need to advertise this in the "For Sale" section, along with the appropriate requirementsHi all the Else is for sale. I'm asking about $1000 Aud but happy for offers. PM for more details
