Zerogee
Clencher's Bogleman
Hi Jon
The pressure is about the same as for an LGB coupler which is less than that needed for an HLW wagon coupling - yes phosphor bronze is much springier than brass or steel - and easier to solder than steel.
Still the same uncoupling procedure as previously, which is one of the main attractions - together with the compatibility with LGB couplings which means I can combine stock with old and new couplings - provided I enlarge or replace the smaller LGB buffers. .........
Rik
All sounds good! I've been looking at your pics and just thinking about ways to perhaps make the design easier to batch-produce.... I am wondering if you could get a small, flat block of plastic of some kind, and drill three holes into the end of it - two to take the ends of the bent loop of brass, and one between them to take the phosphor-bronze hook wire? Then with a single screw hole drilled down through the block to screw it in place, you might have a solution that would do away with the need for soldering at all......?
Just thinking completely off the top of the head here (or possibly talking out of somewhere else...), so please just take it as a "stream of consciousness" idea... might work, might not.....
