Mobi
I fancy a Roundhouse battery loco but I have not seen Criccieth/Harlech Castle in flesh, so few questions for those who have used it (spending nearly a grand on a something which is a "toy" : means I have to be 100% confident before purchase)
Based on a very minimal user manual that is available on Roundhouse website:
1. Is the motor exposed? As per diagram in manual, if I turn the loco upside down, motor is visible and not encapsulated like LGB/Playmobil. This seems strange as I thought it would expose the motor to dirt, water etc.
2. There is no picture of the batteries inside the loco. Can you easily take the battery out and replace with a new set when needed (as in Playmobil 5258)?
3. Anyone measured drawbar pull of this loco? I asked Roundhouse and they replied loco should happily pull 20 lbs weight of wagons - but that is not same as drawbar pull.
4. How do you attach LGB/Playmobil carriages with this loco as it does not come with hook-&-loop type coupler?
5. Roundhouse says loco comes with 1-3 years of warranty (based on offers, registration etc.) but RC system is covered by manufacturer. So, if RC breaks down, then who is will fix it?
6. The manual shows there are lots of switches in loco RC transmitter. But it also says except a couple of them don't fiddle with them. Then why they are there in the first place? Looks like as if Roundhouse doesn't have a clue what the other switches for!
7. As it is battery powered, when battery charge depletes it will become slow and will stop. If the train is unattended, will such incident cause any damage to the loco? I mean, is it safe to run the loco until battery runs out and it stops (without damaging motor/circuit etc.)
8. Did you find any problem with your (Roundhouse battery) loco? Was it a DIY fix or you had to send to them for repair? Do you have to pay for the postage/courier? How long the repair took?
9. What is the nearest similar RC battery loco (feature, capability to haul etc.) you can buy off the shelf? (except Playmobil 5258 which is probably not a like for like comparison)
Any other info you think useful.
Thanx
Thanx
