Tac,TBH, I was thinking of the likes of IP Engineering or GRS, rather than butchering a $500 model...
Had a Eureka moment today. I was in the shed doing some maintenance on my Roundhouse Katie having a mental debate about how I would 3D print a Walshearts gear which ran smoothly and lasted several years. Then it hit me like a thunderbolt! The solution was right in front of me. Roundhouse sell spare sets of Walshearts Gear for their live steam locos and I can see no reason why they would not work on an electric loco. So, when they re-open, my order will be on its way.
Regards
Peter Lucas
MyLocoSound
As for the 'Glaskasten', it was anything BUT a mere 'shunting locomotive -
The Class PtL 2/2 locomotives of the Royal Bavarian State Railways (Königlich Bayerische Staatseisenbahn) were light and very compact superheated steam locomotives for operation on Bavarian branch lines (known generally as Lokalbahnen). There were three types in total, of which two were transferred to the Deutsche Reichsbahn-Gesellschaft as Class 98.3 tank locomotives and even survived to join the Deutsche Bundesbahn fleet after the Second World War.
Common to all the variants was the B axle arrangement (European or UIC classification) or 0-4-0 (Whyte notation), the semi-automatic, gravity-feed firing that enabled one-man operation, and platforms with guard rails, front and rear, that enabled safe access to the coaches. The locomotives had a large driver's cab with 3 windows per side that surrounded the entire locomotive boiler as far as the smokebox. This unique feature earned it the nickname Glaskasten ("glass box") or, in Franconia, Glas-Chaise ("glass carriage").
Very interesting tac. Those smarty Germans again.
Tell me. Do you know why your comments are peppered with hyperlinks? I'm assuming you didn't do that yourself. Just wondering...
I'm not sure if you might have come across it before but I think Accucraft make a model of a very similar Deauville prototype. It was a little more recognisable from the second set of pitures that were put up.
0-4-0 Decauville
I don't know what Accucraft are like for spares, but might be worth seeing if they could supply a set of valve gear, maybe even wheels, separately?
Sadly GRS have thinned down their catalogue rather drastically - you used to be able to buy many of the bits from their kits individually - I used the valve gear from their L&B 2-6-2 on my scratchbuilt 2-6-2 with the same Slater's wheels.TBH, I was thinking of the likes of IP Engineering or GRS, rather than butchering a $500 model...
I've often wondered about using Roundhouse parts - slightly off-piste, but I wondered about a Silver Lady Anne chassis, which would be sprung, and which could then be included in a scratchbuilt, electric powered locoHad a Eureka moment today. I was in the shed doing some maintenance on my Roundhouse Katie having a mental debate about how I would 3D print a Walshearts gear which ran smoothly and lasted several years. Then it hit me like a thunderbolt! The solution was right in front of me. Roundhouse sell spare sets of Walshearts Gear for their live steam locos and I can see no reason why they would not work on an electric loco. So, when they re-open, my order will be on its way.
Regards
Peter Lucas
MyLocoSound
Not sure about 16mm but I did this using parts from everything but sadly it is 45mm but i'm sure you can achieve the same results with 16, perhaps some 1/32 marklin parts
Yes they are the same wheels as used on outside framed locomotives. And they do convert to 32mm, though not since I fitted SloMo’s tommy 2 RH 0–4–0’s. things are somewhat different on their inside framed locs, not even sure if they offer any of these as kits. They are certainly not gauge swoppable. But can be ordered to the gauge you want in most cases I believe.Do Roundhouse do insulated wheelsets, in both 32mm and 45mm?
OR,
Are all their chassis gauge-adjustable?
I believe some live-steam are only on insulated wheelsets in the larger gauge?
