A quick look before running a train is all I need to see if the points are set right.GAP, not trying to stretch this out, just understanding how your switch works with no spring.
If you have no return spring, what happens if you position the points/throwbar mid position? surely a train entering (from the points side) would derail.
I gather your situation is reliable, so with no springs, the train exiting ALWAYS aligns the points all the way to one side or the other?
To me that looks like two R1s with one further forward than the other. It might take up the same length as an R2 but part of it is straight.The LGB 3 ways I own have a straight through, an R1 curve and a possible R2 curve.
Which ever way you go, I would test it using you least favourite (if you have some) stock. The last thing you want is to damage things if it goes wrongThanks for all your answers, I have no care which way around the train goes each time, so I think unpowered unsprung would be easiest.
Is there such a thing as a Y set of points? Particularly one that would fit into an already existing Piko R3 radius corner?
I have both the R1 versions as well asthe earlier LGB production R3 3YP on my railway, as can be seen here....A lot of locos will not go through the LGB 3 way, my first introduction to one was trying to get a Bachmann 2 truck shay through one. Not a pretty sight.
So, please while very small locos will work, it is NOT a nice, gentle, anything works on it switch.
A little research will show up the 2 versions of this switch, but one is long out of production.
