As near as dammit (82.4F)A more pleasant temperature?
28C = 82F
I believe..
As near as dammit (-273.15 C) (from GoogleAs near as dammit (82.4F)
and then we get to the Kelvin scale which starts at absolute zero - which is -273 Celsius (from memory)
Yeah, that was an idea that came into vogue as Denmark has a unit that is somewhat similar. The construction industry started something similar, as a cavity wall 'zone' could be extended to 300 mm.As an aside to the British reluctance to fully embrace metric with our penchant for mixing imperial and metric, the BBC design department worked (when I was employed by by that corporation) in metric feet (ie 300mm) the studio walls and floor had numbers indicating how far along you were in 300mm units
A double-glazed window, naturallyThat all went out of the window when increased insulation thicknesses were required![]()
The plastic stuff that goes round wiresWhat's insulation?
BRRR-ZAP!!The plastic stuff that goes round wires![]()
Watt's insulation? Probably asbestos, same as Trevithick's...What's insulation?
And by the time you have gone through that little lot I have forgotten where we started from.Yep
The calculation from F to C is to deduct 32, divide by 9 and multiply by 5
The calculation from C to F is to divide by 5, multiply by 9 and add 32
For -40 you only have to do the calculation once
So let's start with -40C
Divide by 5 = -8
Multiply by 9 = -72
Add 32 = -40F
Nice loft for a railwayWhat's insulation?
usually around b***** freezin'And by the time you have gone through that little lot I have forgotten where we started from.
Yep
Divide by 5 = -8
Multiply by 9 = -72
Add 32 = -40F
That is why you used :-
Add 40
Multiply by 9 Divide by 5 for C to F (small number to larger)
or Multiply by 5 Divide by 9 for F to C (large number to smaller)
Subtract 40
Sorry, lost the plot on that one - the 32 is important because degrees F have freezing point at 32. You therefore need it in the calculation and, for ease in remembering, it always goes at the Fahrenheit end of the calcCode:That is why you used :- Add 40 Multiply by 9 Divide by 5 for C to F (small number to larger) or Multiply by 5 Divide by 9 for F to C (large number to smaller) Subtract 40
no need to remember where the 32 goes.
So could you show me have this would work for both+40C and +40F with should work out at +40C = 104F and +40F = 4.44CCode:That is why you used :- Add 40 Multiply by 9 Divide by 5 for C to F (small number to larger) or Multiply by 5 Divide by 9 for F to C (large number to smaller) Subtract 40
Greg, agreed, just a mildly interesting point that came to my attention more years ago than I care to remember.Love it when someone says they came up with a new way to convert temperature. The rest of the entire scientific community missed this? Not likely.
The fact that there is a temperature where degrees C = Degrees F is of mild interest, but by itself is not a groundbreaking or necessary fact in the conversion of temperature.
That single datapoint tells nothing of the ratio of degrees F to degrees C (9 to 5) or the offset from zero to freezing in F (32). The ratio and offset are needed in the conversion.
