Re:? Wiring for LGB sound boards from Uintah and Sumpter mallet ??
Mike,
I feel that to get any chuff sound you will definately need the chuff sensor figured out. Otherwise the board will only give startup sounds and bell/whistle if triggered by a magnet.
I would be wary feeding any power greater than 5 volts into the board. The mid-1990's digital boards used power from the main circuit board that was regulated power. Most LGB factory install sound boards relied on a chuff sensor to trigger chuff, so I would not compare this board's operation to the #6500X series boards.
LGB did intend the #6500X series boards to have a chuff sensor input (#65010 from memory, but it never made it into production).
As regards bell/whistle, the centre pin is the common, with the outer pins triggering either bell or whistle. You would need two reed switches to accomplish or the excellent LGB #65012 Mogul function trigger. Be wary if you decide to go the route of the LGB switch as some come with very large plugs to fit your board and others come with tiny Massoth type plugs to fit the #6500X series boards.
If you were wiring the bell/wistle for DCC ops then the centre pin would be positive and the outer pins negative power to provide the earth 'function' return. On DC ops most likely the same.
Mike,
