andyspencer
![United-Kingdom Country flag](https://gscalecentral.net/misc/flags/shiny/32/United-Kingdom.png)
![United Kingdom United-Kingdom](/United-Kingdom.png)
I did hear somewhere that its not a good idea to charge batteries in those battery holders. Much safer to use the tagged batteries and solder them together your self. Poss something to do with the charge rate of the charger?
No, never had that problem. Maybe charging them a bit too quickly?owlpool said:has anyone noticed a problem with batteries heating up on charging with this set-up ?
I use the Cliff Barker supplied charger iaw instructions
melt damage to 2 double AA holders
now have one 8 AA holder [Maplins]and two 2 AA holders, so fewer joins and less spaghetti in the tender
still get a bit warm on charging but nowhere near the "what's that smell?" level
andyspencer said:I did hear somewhere that its not a good idea to charge batteries in those battery holders. Much safer to use the tagged batteries and solder them together your self. Poss something to do with the charge rate of the charger?
yb281 said:No, never had that problem. Maybe charging them a bit too quickly?owlpool said:has anyone noticed a problem with batteries heating up on charging with this set-up ?
Bram said:Mmmm, I would say you had a short there. Recheck your wiring and make sure all wires are insulated properly and that includes the exposed ends of the battery holders. You were lucky not to lose the tender. Also did you fit a fuse?
cheers Melyb281 said:If you do decide to go for a made-up battery pack in the future Paul, these guys will custom build them to fit your requirements;
http://www.strikalite.co.uk/
Thanks IanCoggesRailway said:I have two kits in the post... I have one already in a 2095. I build nimh packs by soldering batteries with tabs, probably the charging issue was down to the holders. just slow up your charge rate. Don't worry about poking your tip out, it will still work with it tucked in and don't worry about the heat either, not seen any even with two motors and long trains. In fact the whole idea of PWM which cliffs kit is based on means less heat build up the traditional speed control.
