Alan McLennan
Dielectric strength... now that's what I'm talking about!I would also suggest that you use a conformal coating if the boards are going to live outdoors.
This will greatly reduce moisture ingress into the boards that will lead to corrosion and possible de-lamination.
Couple of examples
Clearcote DCA Modified Silicone Conformal Coating | Jaycar Australia
Clearcote DCA Modified Silicone Conformal Coating is ultra-clear protection for electronics. High flexibility, thermal resistance, and UV trace for comprehensive coverage that GLOWS!www.jaycar.com.au
2044 | CRC Conformal Coating, 300 g Aerosol | RS
au.rs-online.com
Personally I would use the second one (the urethane, used in the RAAF on avionic boards) as it will be easier to rework the board if needed.
I'll look into it, my power at this moment will be via 12v dry cell battery as used in alarms, with a main switch to turn all power off and a solar trickle charger,
the control switches will be in a box, and servos as before. I knew a few people who moved to Bundaberg.
