Rhinochugger
Retired Oik
Obviously a statistician - but I get the point, you would have thought that the difference was more than a mere 2 mm95mm is not wider than 93mm?
Ah, this modern math, eh?
There's an irony there in that the FR has, arguably, the smallest loading gauge of any steam hauled railway in the UK, while the WHR has the largest for a two footer - a case of little and large when they meet at PorthmadogThere are, I bleeve, only THREE 760mm gauge lines in England - Whipsnade Zoo, Sittingbourne and Kemsley [SP?]. and the W&Ll. All of their locos have run there - 'Superior' this year at the gala weekend.
On the other tentacle, the vast majority of Welsh NG are around the 2ft gauge, with correspondingly dimensioned rolling stock. One of those 'little Welsh railways' also has the largest 2ft gauge locos running in UK - the Welsh Highland railway runs a number of the magnificent ex-SAR/ACR NG/G16 Beyer-Garratt articulated locos, and yet another, an NG/G15, formerly running in the grounds of a tree nursery in Switzerland, is due to be running on the Vale of Rheidol railway soon.
Obviously a statistician - but I get the point, you would have thought that the difference was more than a mere 2 mm![]()
Talking of statistics, it's a little known fact that 8 out of 5 people cannot do fractions....
I wonder if the smaller roundhouse diesels (bulldog, Merseysider, little John) would look small against both sets of stock?
Here a some pics of the SR (L&B) and W&L stock with a Roundhouse Silver Lady and the Bachmann Lyn. I believe the SR Brake Van was added by SR after the Big 4 consolidation and has a similar loading gauge to the W&L stock.
Roger
I always thought the Baldwin 2-4-2s were 1:20.3 - they're certainly listed as suchIt might be worth mentioning that the Bachmann Lyn shown is scaled oddly around 1:22.5 in scale given that 1:19 (16 mm) scale is used by the industry to reproduce "prototypical" UK NG locos and the stock pictured. Roundhouse's Lady Anne is a "freelance" model loco design and considered by some, while a long term favorite, to be a bit "beefy" compared to others. So much so that one of the UK's most prolific laser cut rolling stock makers, IP, made a special range to look "right" being hauled by it and others from the RH range. This can lead to some proportional mixups. But as has been mentioned there is always "Rule 8"to cover that. Max
I always thought the Baldwin 2-4-2s were 1:20.3 - they're certainly listed as such![]()
Yep, as above, but even acknowledging the length issue, the Bachmann version would be 15mm:1ft while the Accucraft would be 16mm:1ftI've noticed in the past there has been some conjecture on that issue. Not too far off on height but way too short end to end at the buffer beams. I started out early on, 15 years ago, with a 2nd hand Bachmann Lyn/Baldwin then a year later I got the Accucraft - my inner rivet counter was released at that point due to the shock of my ignorance as to their scale disparity was so greatNothing has been the same since. Max
Accucraft 16 mm Baldwin
And my Lady Anne, with a 1:22.5 scale standard gauge prototype (G3) Wisbeach and Upwell tramway coach fitted with 45 mm gauge axles
You beat me to it Rodger K
'twas on your list as Sittingbourne and KelmsleyAh, Bowaters Paper Mill - THAT's the 2ft 6in line I ALWAYS forget!
