Madman
I have a couple of #3 Stainz locos. I still use the old style banana plugs. So what I do is open the bottom motor cover, slip a wire between each pick up skate brass plate and the silver rod that holds it in place. Then I run the wires out the back of the motor block by making two small notches, just large enough to allow the wire to pass through. I the install a female banana plug on the end of each wire and insert the plugs into 9/64" holes I drilled in the red cross beam at the rear of the loco. Once the plugs are in place I hot glue them in place. I use these plugs to help power the loco via LGB ball bearing wheels on each car. All of the cars in a consist are plugged into one another.
