We had a rake if those on the Ruschbahn, Andy made them look more European by removing most of the fiddly detail and putting a platform on either end.As the weather has turned for the better and the sun is appearing decided to get out and run a recently purchased train.
The ore wagons were an impulse buy, but make they make a very nice rake, and will help improve the already substantial freight shifting service available.
Dan
View attachment 281973View attachment 281974
One of my like to do battery jobs, reckon a split pack either side of boiler would work. 6AA each side, cab be hidden by plasticard to.It’s been a year since my last update, the railway hasn’t been idle, I’ve just forgotten to update post photos
So here’s the first run of 2023! Hopefully will be able to post a lot more photos this year
the loco is currently running with a battery wagon, as space is snug for onboard batteries.
It’s on the never ending todo list!
Dan
In the meantime a pan push down should help, stiff wire bent up from the tunnel either side to above pan greatest height works well. Around a foot or so either side of the tunnel. Fitting may be a task but if you can manage to drill a couple of holes for brass screws so you have something to solder to. Will give you a good start for when you do the full thing overhead wire wise.Latest train update!
Despite a lack of updates, trains have run and things have happened,
The line has invested in its first electric loco, it’s a fantastic beast and looks amazing running round the garden,
I’ve also acquired the second set of iron ore wagons, which now fitted with metal give a very pleasing sound over the rail joints,
The full set of iron ore wagons just fits in some of the loops, so will need careful planning when in use as to where to stable them.
Another issue that has become apparent is that running electric locos on a line not built for them is the clearance issue for the pantograph, but this will be fixed in due time with fishing wire
Dan
