CoggesRailway
beavercreek said:Due to the power hungry nature of the USAT/ARISTO large diesels, I have cast AA sized cells aside and am concentrating on the maximum number of SUB-c sized cells that In can fit into the hoods alongside Aristo Revo boards, sound board etc.CoggesRailway said:I know there are loads of people who "know best" about this topic. However i run heavy trains with batteries so it may be worth listening, even though i am no chemist. U do need to forget AA. Please watch this all the way through. Nothing more than single pack 14.4v nimh sub c. The alco pulled this for over two hours. The drag on the drawbar was huge - I pulled it my self by hand to see!
I guess the key is get the most umph you can for the physical space- and invest the money to buy good quality/capability.
I have also found diode protected paralell packs a good solution, simple to do.
http://www.youtube.com/watch?v=xQoHGmmid44
I have not discarded the use of fully protected Li-Ion packs like the Aristo ones as they pack the power for smaller space.... BUT one thing that I was told by the aero/racing fraternity was that Lithium chemistry does hate the cold and that if I store the locos (with the batteries inside) in a cold environment (which they will be) the Li-Ion packs will not work optimally.
So I thanks all you lads greatly and also to the advice from the good trustworthy retailers.
Small locos...AA NiMH or small protected Li-ion
Large power hungry locos.... SUB-c NiMH or larger protected LI-ion
If size of void in loco is a problem then Li-Ion
If no problem with void size, then SUB-c as they are a lot cheaper! (they also have one more advantage..they add more weight for traction)
I will go for the 19.6V option as, although i do not run fast trains, I do have to climb large inclines and will need to drive the locos harder. DCC boards have back-emf but Aristo Revolution boards do not.
Sounds like sensible conclusion to me. Sorry if I sounded grumpy back there I just re read it !
