Tortoise Turnout Motors
Hotbox
27 Nov 2019
9
Brentwood, TN
I have several Tortoise Turnout Motors by Circuitron that I used for n scale. I’ve built a mock-up and they are strong enough with enough throw for my G scale turnouts. I’m wondering if I’d be able to protect them in “weather-proof” boxes so the elements don’t corrode them. Anyone with experience or ideas?
Thanks
5,010
76
I would have though a big worry may be small insects getting inside the delicate gears, they can and do get in through the smallest of gaps.
Neil Robinson
579
N W Leicestershire
Thanks
My local area GSS group's layout has two, for indoor or occasional fine weather outdoor use, fitted under the baseboard operating "Peco" G scale turnouts. If I recall correctly these are at about the limit of the motor's throw. Regarding outdoor operation I suspect it's down to how weatherproof your weatherproofing is and the brand of turnout.
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
Lots of things that can corrode in humidity that will occur even in a "weatherproof" enclosure. With the limitation in travel and the exposed contacts, I think you would be way better off with LGB or similar motors.
Hotbox
27 Nov 2019
9
Brentwood, TN
Thank you, I see what you mean, I keep thinking I can design something that will work. Or, even better find someone who has already accomplished it and copy them.
