Aha, thanks! I knew I'd seen the title somewhere...... Yes, always good to keep your nuts in a plastic bag for safety.....
Don't you have to hang the bag round your neck?
Especially, in Epping Forest!!
That's a good idea. Hopefully I don't spend tooo much there this year.....Look @ the Springfield show : Large Scale Central - Event Profile - Big "E" Train show in Springfield Mass.
Have to be honest, I don't hang the bag with my nuts in, around my neck!!Don't you have to hang the bag round your neck?![]()
I am not allowed to take the Clean Machine to bits, as it belongs to my better half!Have just managed to get my Piko Non Track Cleaner to bits for investigations into Battery Conversion with Sound and Radio. Hence buying the best valued one rather than the additionally priced BatteryTrack Cleaner. Simple pull apart except for the Cab from the Hood. Trick was to gently lever where the slot in between the two and it started lifting. Almost as tricky as a Playmobil 5258. Only damage was one window surplus glazing broke. But as I plan to remove as much of the surplus plastic around the glazing as possible not an issue. Here she is undressed as it were for any of you too timid to pull one apart, but interested in the guts. In truth if you Chip it with a Piko Chip you will need to do this pull apart except for perhaps the Windows.
Note all the small bits in a Plastic Bag to save getting lost. Be a while before I attack this little treasure
Can you give us the dimensions (diameter and thickness) of the area for the speaker? Would love to see backside of the cab roof.
Thanks, Greg
Is it the same motor in the blue one as in the battery one Jon?
Says the same on my paperwork 36000.Wait one... I will get the (cleaner) parts-list....
Parts list gives it as Part No. 36000 ..
Now, if JonD can look up the part number of the standard model??
Been on Piko webby-site, and the part number is the same for the other models..
So it looks to be the same motor??
Yes in the roof. Almost as near as I can make it, but not quite exactly but very approximately getting on for probably 4.5mm. There is a circuit board that holds any speaker in place and this has a circle of 26mm and the circuit board is probably around 1.75mm deep.Thank you Jon... that speaker mount is inside the cab roof, right? any idea how deep that area is? might be hard to figure. A small speaker like that won't be very deep at all.
They show a #36122 decoder replacing the main board (I called the screw terminal board) and it wires to the front and rear and cab lights and the smoke unit.... no mention of sounce, but the SUSI interface is pointed out in the diagram... so apparently a separate SUSI sound decoder is required for sound.. plus the speaker of course.
