Trams: Is There Much Tramway Interest On Here??
A pic, copied across from David's Pic of the Day, 24.11.24, showing a street scene in Soller, Mallorca, with a tram, bound for Puerto Soller, trundling along, 16.9.2024.
A pic copied across from David's Pic of the Day, for 5.1.2025, an abridged view of the Whiteleaf Tramway, on display at the Solent Local Area Group (SLAG), G Scale Society exhibition, Wickham Community Centre, Hampshire, 17.11.2024.
The Parramatta Light Rail opened just before Christmas as Sydney line L4, but it's taken a while to get across the city to ride it. Most of the line has trolley wire, but two sections in high pedestrian traffic areas are wire-free, with the CAF LRVs running off batteries.
The line from Carlingford to Rosehill Gardens is double track on a former single track heavy electric rail right of way, while the rest of the route is partially on new reserved track and partially in new roadway reservations. One bit through the Parramatta CBD follows the route of a steam tram service which closed nearly a century ago.
View attachment 337856View attachment 337857
Always good to hear of an old tram route even in part being resuscitated, shows that the early fathers of Trams got things right.
As many of you know, I'm a Signalman for Network Rail. At my Signalling Centre in York, we control Rotherham. Part of that means we signal the Sheffield Trams (TramTrain) on to and over Network Rail metals. Here are some pictures from a site visit last year. And some pictures from inside my signal box on Rotherham Workstation, a seemingly secret world :D
Below is a view from Meadowhall South, turning right takes you under Tinsley viaduct onto the Tram Transfer Line, where they convert to trains, so to speak. If you go straight on, that's conventional tram to Meadowhall.
A TramTrain taking that right hand turn, where it will pause for a moment and set itself up as a train, ready to be signalled as such, amongst heavy rail trains, including freight from an increasingly busy Tinsley Yard.
The transfer line where trams convert
The TramTrain having converted, now sends an electronic request to the Signaller on Rotherham Workstation and when accepted on to our network, will receive a signal allowing the TramTrain to proceed through these sprung points and along a long spur where it will join the Tinsley lines, bound for Rotherham Central and ultimately Parkgate Retail Park.
A general view of the Up and Down Tinsley, close to Magna, where a new tram stop is getting built.
The TramTrain end destination for now. Parkgate. In the picture is a spoil train taking earth from HS2 excavating to Tinsley. The spoil is being used to landscape old mines and quarries in the local area.
The Sheffield Tram control room who in effect, fringe with Rotherham Workstation NR.
A close up of the area where the Signalman first has dealings with the TramTrain. The arrow shows the TramTrain Transfer line mentioned further up.
Below is the entire Rotherham Workstation. Again the arrow shows where we get first interaction with the TramTrain for it's journey to Parkgate. I'll let you find Parkgate on the Workstation.....
Hope you found that interesting. This is from a Signalling point of view. This is the only TramTrain in the UK at the moment. It was implemented well over schedule, as like usual we had to reinvent the wheel, despite similar systems in use throughout Europe and the world for many years. It has however been a massive success. Hopefully it takes off in the UK and indeed other areas of Sheffield. But, this is the UK, and I'll probably be in the ground before any additions to the network are done. Because, we will have to talk and consult about it for 20 years, before we do anything..... Such is the UK.
Nice to see the ops side of TramTrain, the next stage of TramTrain will be starting in Cardiff this year I think but as yet only on heavy rail till the street sections get built. I wonder what route that 66 with the HS2 spoil used, to my mind it has come from the wrong way unless it came Down the ECML to access Tinsley via Doncaster and Parkgate?
I will find out for you.....
What does the 'conversion' process entail?
Driver changes hat and jacket?
Pump up the tyres, to work on heavy rail?
:D
Thanks Duncan route as expected, much more freight heading through St.Neots these days. It did get down to one each way a day some time back but has been growing considerably in the last year or so. Though the container train I saw on Thursday morning just after 0600 had an awful lot of ‘fresh air’ in the consist with just a handful of boxes at the front end. Though to be fair most I see are well loaded.
:D
:D
They switch off the tram radio network and activate Network Rails GSMR system for communicating. No distractions allowed from the generic tram radio system. TPWS, is activated, along with AWS so that they are compatible with Network Rail so to speak. This allows them to be Signalled with full heavy rail safety systems in place, as up to this point they have been driven on sight only with no block sections.
Yes, the container freight has saved rail freight in general, now that we don't have any industry.
Thank you for the explanation..
I will admit to slight confusion around Nottingham, what with changes to road layouts, tram and road junctions, and signalling..
There can be too many signs, in some places.
This pic has been copied across from David's Pic of the Day for 23.1.2025. A kit bashed maintenance tram running on the Whiteleaf Tramway, on display at the Solent Local Area Group (SLAG), G Scale Society exhibition, Wickham Community Centre, Hampshire, 17.11.2024.
A pic, copied across from David's Pic of the Day for 01.02.25, is a view of a tram running on the Whiteleaf Tramway, on display at the Solent Local Area Group (SLAG), G Scale Society exhibition, Wickham Community Centre, Hampshire, 17.11.2024.
ciao, a little upgrade from my layout (tram, Italy): one side of layout is almost completed, on the left the track for (future) depot. A mix of LGB, 3d and traditional railmodel technique...
Can't get a more Italian looking scene, especially with the Fiat 500....
