Greg Elmassian
Guest
Yep, Volt Amps to the rescue... not! Something that has to be repeated often in this hobby, VA is not the same as Watts at ALL combinations of volts and amps. The definition of VA is that there is a point where volts times amps equals the VA rating.
The VA rating is NOT, repeat NOT available at all combinations of volts and amps.
I really found this out trying to run my LGB cleaning loco with a power pack that just could not run 24 volts at basically any reasonable load at all... so a 60 VA unit that advertised 24 volts could not give me 24 volts with 2 amps... (which would technically be 48 VA).
