ARIA31
I little bit late , but I finally solved the coupler issue by installing a Bachmann couplers similar to those installed on all my Bachmann rolling stock.
I removed the LGB coupler and screwed a Bachmann coupler and luckily the screw hole was at the same place on the 2 couplers ( thanks to the designers !! )
But afterward I got several derailments. At first I suspected my track ,... possibly the Uintah engine not suitable for it ....
By hazard I discovered that there was an interference between the coupler vertical rod and a pneumatic hose.
So I sadly removed the hose and now everything fine.
I have a new question about lubrication .
Is there a trick to put conductive oil in the more than small place between the wheel and the truck body ?
If somebody can help me ?
