So it's felt like not much has been going on recently, many kilos of stone moved around, the stone platform is built and roughly at level, but things are not quite ready for actually running trains on.
On the plus side we have a new cargo for the hopper wagons, catkins!
The biggest block to running any further was a 90 degree 10ft diameter bend that needed to fly over a water feature / river.
I'd mocked this up with a chimney pot per a previous post and just resting track directly onto the chimney pot and some concrete blocks, but given the water below and the uneven gradients this was never going to be suitable for running, especially given the prior fall.
So as I had some plywood and some 3 by 3 inch lengths I thought I should be able to put together a temporary bridge which would be sufficiently safe/durable to allowing running onto the next length across the stone platform.
The bridge was made by cutting the plywood into rectangular segments, laying the track over these as a template, removing the track and then gluing these to short lengths of the 3 by 3. This was left for two days to dry and then was turned over and screwed together to make the finished bridge.
To allow the chimney pot to fit under the bridge two 3 by 3 chunks were removed and back wall added to transfer the load across the gap. On the front face a couple of thin off cuts were screwed to ensure there wasn't front to back twist. My hope is that if a train is driven too fast it should fall to the back, and perhaps in time I can add a fence of sorts to the front so the trains are visible but safe.
The bridge is not perfectly level just yet, and I'll likely need to paint it as I suspect that temporary might mean a year or two. But I'm hoping be the weekend I'll be able to run to a new terminus on the stone platform itself.
As for final designs I'm considering a modern stressed concrete style design, potentially cable stayed, (
Erasmusbrug - Wikipedia) the thinking is that the current chimney pot is not centred on the span, I could add a second pot, but that would involve more cutting, levelling and I feel that two pots would end up with the bridge being more supports than actual spans. Moving the current pot would be a pain, and I actually like the current visual effect.
