trammayo
So, Greg, you think the traction tires are the culprit, in the cracked axle mystery ? Just as an experiment, I took a different approach to rehabilitating the broken axles on the loco I purchased. I figured why not give it a try, I have new axles on order. It's how we learn. So I pulled the wheel/axle assembly out of the gear and cleaned the grease off everything. Next I put it all back together. Then I placed the completed assembly in my drill press vise and drilled 1/16" holes through the gear shoulder, into the steel axle and out the other side. Next I pressed 1/16" brass rod into the holes and cut the excess off flush with the gear shoulder.
All seemed good until I checked for wobbly wheels. Holding the axle ends I spun the assembly. I noticed a slight eccentric movement in the gear. I know what happened. The splits in the gear shoulder were the problem. They created just enough room for the axle not to sit perfectly straight. If you look carefully at the photos, you can see what I mean.
So has anyone had experience with the performance of replacement axles ?
View attachment 207209 View attachment 207210 View attachment 207211
If you could have sleeved the gear shoulders, you might have been able to make the gear concentric (the operative word being 'might'!).
