Sarah, on an other thread there is a really good drawing of the DPDT switch
https://www.gscalecentral.net/attachments/sarah-switch-loop-png.238267/
The important thing is to make sure the polarity is correct according to which way the switch is pointing, ie. which "end" of the switched section you are going to drive into.
Sarah, don't thank me the drawing is Neil's, I just pointed you at it.Thank you everyone and for the drawing JimmyB.
I hope tomorrow to have my loop set up if only temporarily.
SW
I'm persevering with my DPDT loop.
Oh, I don't know what happened but I've gone all bold!
Each dead section of my loops will be a station. I'll put the switch in the centre off position and align it parallel to the track so I know which direction to push the switch will be the direction I want to train to go.
Quite righ as Phil says. This is why I suggested the Switch near a point and using the way the switch was pointing to indicate where the power was being supplied from.Except the 'polarity' of a DCC track has no bearing on the direction of travel of the train..
You are supplying 'power' and 'control-signals' over the track.. The decoder in the loco uses the power to make things happen, and the control-signals to say what will happen.
On a DCC track, a chipped loco will travel in the direction you tell it to go.. Whichever way 'round' you put it on the track, forwards will be forwards..
You really need the LED's to tell you 'green is go' across your isolation gaps.
Still confused, I'm afraid.
My controller supplies the track with an AC voltage. Through the pick-ups this voltage is supplied to the locomotive's motor via the decoder?
My controller has "forward and reverse". Are they redundant if which ever way round I put my locomotive on the track it will always go forward? Now I know that can't be right since the unit does go in reverse as well as forward.
So obviously there is something which recognises which way is forward? Is that in the decoder or the controller please?
SW
No you do not need TWO DPDT Switches only the ONE as I said. I propose a DPDT Centre Off so that there can be no flashover within the switch when you change polarity.Yes, definitely, thanks.
I understand (without knowing the technicalities) the addresses and how they have to be assigned to different locomotives.. So something in the CS knows which way to send a locomotive when it's forwards and reversed buttons are pressed and go faster control is turned?
I acknowledge that having diodes would help but I don't have them so I'm relying on me setting the DPDT switch correctly. If then I wire up in accordance with your drawing things should work.
The sequence should be, I have my DPDT switch (say S1) set to allow a train into the station, from the RHS, with the other end LHS cut off from any power by the isolated rail joiners. I stop the train, set the switch (S1) to the centre position and the isolating rail joiners cut all voltage to that section of track.
When the train is ready to depart I change switch (S1) to the other position allowing power into the LHS station track now unaffected by the isolating rail joiners at that end.
The only question now in my mind is do I need a DPDT switch at each end of my station track, please?
I'm sorry for all the trouble and probable frustration I am causing.
Sarah Winfield
If you did this in DC the loco would be running Bunker first as DC will still be the same polarity to each rail.
What? I think you may have been away from DC for too long. Please read what I said again. Or are you refering to an Analog Locomon DCC? Which could well be a different scenario.Gotcha!
(Warning to Sarah! Severe thread drift..)
Analogue loco, pickup AND motor connected together, on each side...
If you turn analogue loco round, you reverse BOTH pickup and motor. - You only reverse one to alter direction of travel..
So the analogue loco will still go forwards..
