I have never seen anyone use 30 volts to a TE, and believe it has been damaged.
You did not mention you checked the fuse on the base unit. The manual says the receiver works on 15 to 20 volts DC, you are way over that.
I suspect it worked for a while and then quit. These units also do not work well on lower voltages, like 12 volts.
