So, Greg, you CAN run these is series then....? I assume that to do this, you connect the +ve supply to the + terminal of the first strip, the -ve terminal of the first strip to the +ve of the second strip, then the -ve of the second strip back to the supply -ve.....?
OK, going back to one of the earlier questions about reversing polarity through an LED..... I'm part-way through dismantling the little railcar in question (the same one for which I asked the questions about USAT motor blocks in another thread), and the more I uncover the more puzzled I'm getting.
The vehicle is wired for analogue operation. At the front it has two yellowish LEDs for headlamps, and two more red LEDs at the other end for tail-lamps. As far as I can see, each LED has a limiting resistor fitted, but there is NO other protection for them such as inverse diodes, bridge rectification etc. When the vehicle is moving forwards, all the LEDs illuminate (head and tail lights). So far so good..... but when the vehicle is run in reverse, none of the LEDs light at all - which is as I'd expect, since they are getting the wrong polarity - BUT they don't burn out or seemingly suffer any kind of damage or ill effects. Turn the controller back to forwards voltage, and all the LEDs come on again just fine.
This is very much at odds with a lot of the posts above, by the answers given earlier the LEDs should all have burned out the first time the vehicle was ever run in reverse! Can anyone shed any light (pun!) on what is going on....?
Jon (Confused of North Essex).....
