I use a micro propane flame to solder track. Clean the join, a little solder paste and indirect heat from the torch, very quick and efficient. You can buy the gas torches in quite a few places.Just brought a rather nice soldering station from Aldi.
Has a couple of small spare tips too.
Probably not good enough for track work though? I would use a gas powered soldering iron for brass rail work....
The only problem with the tips on the propane torches is that they dont have a lot of mass which means you need to pump the flame into them to solder big jobs.I have a micro torch too, but it also has a soldering tip, lots of heat quckly.
For occasional use, you will be more than happy with a temperature controlled jobby from the likes of Aldi / Lidl..
As I say, mine is quite often 'on' for six-hours at a time, a quite different prospect to your use, no doubt?
However, Do PLEASE remember to turn any iron off! - Perhaps arrange a 'breaker' for the whole workshop? - Or most of the work-bench(es), at least??
Extremely good post, thanks, BillIn my track-power days, I bonded every rail joint with wire and soldered jumper wires across every point. I never had a problem melting sleepers. As Phil says, you need to make sure the bit of rail you want to solder is clean. I found, the heat dissipated quite quickly from the point of contact with the iron and only needed a heat sink when soldering very close to the plastic frogs of points.
Here's a close up of the jumpers on one of my points. As you can see, no evidence of melted plastic.
Link to the blog post explaining what I did - Peckforton Light Railway: How I repaired LGB pointwork
Rik
