The cab looks great! But the fingers are rubbish. - They don't look real at all!![]()
Give 'em time.I say surprisingly because the thin brass foil bands on the domes are CA'd and I was pretty sure that wouldn't be suitable.
Well done!
Give 'em time.
Safety valve needs some attention if it is lifting at 30psi.
Yes good plan ensure that the pressure gauge is reading correct at blow off which should be 40psi. Then put the replacement one on and adjust to blow off when you get to 40psi. That is assuming of course that the original safety valve is set correct and that the PG is also correct. do you know how to reset the gauge? RH ones can be done by carefully winding the top with a pair of fine tweezers. You should not need much adjustment to get things correct. Wish I could remember from my Boiler Testing days which way to wind them!I suspect you're right..
Thanks for the spot re the pressure. I'd thought the safety seemed to be lifting early. I need to look at that. I've swapped the gauge so it may pay me to pop the RH gauge back on to double check it's definitely the valve and not an under-reading gauge first I suppose
Be careful, you don't want too much pressure
I use replacement safety valves from Wee Bee Locomotive Works. They are a proper safety as in they blow off then reset and do not weep/waste steam. They have a ball with a spring to keep it seated inside them. You can get them from The Train Department if your stateside or Anything Narrow Gauge(I believe has them) in the UK. Beautiful work on making a fine model even better! AD
