Have you checked the gauge of the wheels? If you could ease them in a little it might help it get around curves.dunnyrail said:On Setting 1 it came to a stand at pretty much every curve. As these are 4ft that is not good. However on Setting 2 it went round OK. On the Gradients as it started to Slow Down I put it to Setting 3 and it continued just fine. This was with 2 LGB Harz Coaches and a 4 Wheel Van all with Metal Wheels. So if it is driven it turns out to be just what the Doctor Ordered. Now very pleased indeed with the little Baby.
Nice work JD....dunnyrail said:As promised some pics of both Normal and Baby Kamel.
Something else to try. Wipe a little vaseline on the inside of the rail heads of the sharp curves (and wipe it off the rail heads !). If the loco goes around it better, then the problem is with the wheels/gauge and not to do with the gears or motor.dunnyrail said:Good idea gregh, I think that I need to open up the Chassis anyway as there is a nasty noise from one of the Gear Trains. It has not had much running so cannot be much bad. I think that the grease needs to be redistributed. That would be the time to revise the B to B a little.
Couldn't find this on the Amazon site?dunnyrail said:The Swiss 3 Car Set 7938 is available at around £150 from the same source. It surprises me that no one from the Forum has posted about this set. It would appear to be a somewhat similar set up in terms of Radio to the 5258.
