Aristo Mikado joins the fleet
Nice, the PolySwitch (it's not really called a polyfuse strangely) PolySwitch Resettable PTCs Devices - Littelfuse is a nice resettable device.
If you look carefully you can get ones that have tighter tolerances, but while for sudden shorts, you rate like a regular fuse (trips at 200%), at constant loads that don't spike a lot, they trip pretty colse to the rating.
The "thermocouple" is really a thermal switch, right? So on off should yield pretty much full voltage... are you going to use 20 ohms on the resistor? If so, max amps of about 0.74 would mean a 2 amp Polyswitch might bet technically better, I doubt you will get much of an inductive "kick" at this current and voltage, even though the resistor is indeed wirewound.
Nice idea, and the only question is what duty cycle will be necessary to keep it "warm".
An interesting solution to a common issue.
Thanks Greg!
Sorry, yes polyswitch :)
Correct the thermal device is just a normally closed thermal switch glued to the outside wall of the metal tank.
Two holes will be drilled in the tank, silicone bungs inserted and then the heating element put inside with the legs pushed through the bung.
I have a few thermal switches to try, rated at 25, 30 and 35C. I'll start low and try to compare the switching temperature with the actual water temperature.
I had wondered about the duty cycle. It will be interesting to monitor it. I think it might pay to pop an LED into the circuit so the heating cycle can be observed (I'm not sure though, how one could be incorporated between the thermal switch output and ground... edit: PhilP sells prewired >18v LEDs which should do the trick!)
I've seen a pretty simple water level detection circuit made with a power mosfet and resistor, but it would mean two more holes and bungs for the 'sensors' and I'd guess the polyswitch is safer given there's a heating element invovled. its not as if all the water in the jacket is going to evaporate during a run.
Well I've taken a close look at the tank... oh my gosh. The space to get the heating element into is pretty tight and whilst I was hoping the outer tank shell might disassemble, it doesn't.
So it's going to need a 4.7 mm hole for the element insertion, into a space that is 6mm. Gulp20201004_094345.jpg
Darren,
If the water-bath dries-up, then the resistor will just get hot. - The polyswitch will only trip if there is a fault.
You *might* be able to use two polyswitch devices? - The first close to the battery, as a general protection device.
The second, you would glue to the resistor (I would not bother removing the casing, of the resistor). - You would have to test this, but my theory is if there is water, then the heat will be transferred into said water. If the bath is 'dry' then the resistor (and the attached polyswitch) wold get hot enough for the polyswitch to trip.
A 'water-level detection device' would probably be a better option? :think:
Darren,
Thanks Mr P
I'll hold off on the whole 'is the tank dry?' circuitry for the time being and diligently check the water bath.
If I can get the thermostatic heating working first off, I'll treat that as step 1. I've ordered all the bits and a little tin box to test with. I've ordered a >18v led from your good self which I will place across the heating element to give a visual indication of the heating cycle.
Once set up, I'll post some video of it all in operation
NB I've dropped the battery specs to an 11.1v 8.7ah li-ion, on size and cost grounds
NB I've dropped the battery specs to an 11.1v 8.7ah li-io, on size and cost grounds
Do be careful!
Not sure of the actual model of battery you will be using, but even for testing... Before anything else... Fit the fuse! :):nod::nod::nod:
I would expect the battery to be able to supply 'several-C' as a burst of current. - Things can get very-hot, very-quickly. :(:sweating::eek:
NOTE:
A Polyswitch is a thermal fuse, where the internal 'substrate' melts to break the circuit.. If the Poly does 'trip', it too will be hot.
Clearly the circuit should be designed to handle worst case current... that would be the current drawn with the resistor in open air.
Next you want to really see if you can tune the circuit that if the resistor becomes uncovered (no longer in liquid) than the overcurrent protection would trip there.
If you get that down, you will probably be fine... I would try to design the system so that the resistor sits in liquid even if low (thus horizontal), and put the temp sensor low on the "water jacket" too.
I like the idea of the LED, will help system tuning if nothing else.
p.s. the "tuning" of the circuit does clearly involve setting the "on" resistance to draw the design current, thus the danger of "a burst of current" really does not exist unless you have some failure. A fuse really won't help much other than something failing (still a good idea), your tougher challenge is tuning the circuit to maintain the temp, and to not be "fooled" by running out of water in the bath.
Here's an example of the simple low water circuit I had been considering for step 2.
In this example circuit, water touching both probes would cause the LED to illuminate. When the water level drops sufficiently to uncover the 'high' probe, the LED goes out.
I've yet to work out how the circuit could be incorporated to control the supply voltage to the thermal switch
Thanks for making me feel like a bear of very little brain Phil! How did I overlook that simple fact? :)
So all I need do is attach one side to the brass tank and I could reappropriate the filler hole (bottom of the photo) to use an insulating bung with the 'high level' side of the circuit...
Re: the water detection circuit. To my limited thinking, it seems as though I could put the start of the heating circuit (the input of the thermal switch) after the LED on the mosfet Drain leg.
That was my attempt at weathering the valveger :D
My first, which is why it's 'sub-optimal'
The Vallejo oil top-wash was quite effective but I think I started too light with a Tamiya silver basecoat which I then tried darkening down with an ink/isopropyl wash. It's perhaps ended up too light and patchy
Well I've had a go at testing a non-invasive version of a tank warmer.
Bench-testing seems successful. I thought I'd have a go at using a peltier module to heat the water, rather than drill holes and immerse an element.
I also found a nice little programmable thermostatic control module. So for about £10 I have something that will keep the water jacket at around 30C
Current draw at 10.8v (intended battery voltage) is a whisker over 3A.
Here is a video of the circuit cycling.
Peltier tank heating test
Waiting for the water to cool is a bit boring. If you watch the video, just skip towards the end.
Here is the actual installation, using battery power.
The thermistor is a perfect fit for the fill hole so I may use that rather than obtaining an external reading from the tank skin.
Battery heating of water jacket
I still haven't gotten around to steaming the Mike, but it now has a much improved smokebox door plate, courtesy of MDC Plates and has been renumbered to 19.
The quality of the plate is excellent. Dimensions are spot on and given I only provided a reference photo, I think it's spot-on!
Number 19 now has an alternative tender.
It's on the winter project list as it needs a bit of attention, but I like it because it's a bit unusual. I dont remember seeing any other triple-axle Vanderbilt tenders for the live steam version of the Mikado
The main tank body houses a gas canister which screws onto a regular fitting and control valve.
It must have taken a fair bit of confidence to take the knife to what is a slightly less common and unmolested tender but it seems to have worked.
The charge socket for the battery which would normally be on the top has been relocated beneath. Likewise the indicator LED now lives discreetly on the bottom side.
I'm less impressed with some of the implementation; the charge socket location puts an uninsulated positive terminal extremely close to the metal gas tank and the main electronics board is allowed to float in thr main cavity supported, along with the top of the gas bottle, on foam padding!
I have it all apart and will look to make it all good. The gas cannister approach may make way for a cylindrical fuel tank which can be refilled through the top hatch.
I will do the 2.4GHz RC conversion as before although am going to see whether I can use micro servo decoder boards rather than full size ones this time.
