Hmm, I need some wisdom from the masses on this.
I've been rebuilding the Vanderbilt tender to try and improve it a bit.
I've printed out a tower to hold the electronics properly
Heres the bit I could do with some advice on. Although it was quite ingenious, I'm not a great fan of the gas cannister in the tender idea, mainly because the tender needs to be disassembled every time the cylinder needs to be replaced. Given the cylinder is approximately twice the original tank size that means every two runs AND a close eye must be kept on the water as it would always run out before the fuel.
So I've opted to replace it with a neat little Bix tank. I can line up the fill port to be underneath the hatch feature on the tank body which is quite neat, but it puts the tank valve in an inaccessible position under the tender shell.
I don't want to cut extra openings in the tender so I'm wondering if I can put a hard line in from the Bix tank outlet, through a control valve in a better location and from there off to the loco.
By doing this, I'd need to keep the tank valve permanently open and control gas delivery through the new, remote valve
Heres a picture of the tank and fill port access
Does that seem like an okay approach?
