Rhinochugger
Retired Oik
Does anyone have experience of setting up the chuff triggers on this loco - it looks a bit complex
Ah, and that, I think is part of the answer.Early Bachmann 'triggers' were a springy strip, pressing on an enlarged plastic section on the axle. - Purely mechanical, and suffered from chronic 'switch bounce'.. YOu either had to build electronics to de-bounce the signal, or suffer with syncopated chuffing!
Yep, thanks.I thought the chuff trigger was a connection on the board, should be a normal negative going trigger, hook right to your sound card.
What card are you using?
The chuff adjustor is a small piece of plastic with a "flag" sticking up that interrupts the optical sensor beam, it rides back and forth in the cylinders.
You can fine tune it to come out exactly when you want, normally not needed.
here's the pin connections: https://www.bachmanntrains.com/home-usa/dwg/dwgs/LS_C-19.pin_assignment.pdf
Not difficult at all.. you want pin J1-5
You go here to get the documents you want: Bachmann Trains Online - Contact Us
Just scroll down to the Large Scale section, and you will see several C-19 documents.
He was well informed to not want to use the Shay triggers, they are a pain, and usually do not stay working without periodic adjustment. That said, I would use them to get the prototypical timing and the fact that they were 3 cylinders, right?
Greg, the sound board is the basic Annie sound board with George Schreyer's enhancements.I forgot to re-affirm you have to power the main board, which powers the circuitry for the optical chuff triggers.
You need to take the chuff connection on the tender board to your chuff trigger input on whatever you are using... it will pull to ground when it "wants" a chuff.
3 wires to the bachmann board, power, ground and the chuff trigger wire to your sound board.
p.s. you never replied what sound card you are trying to hook to.
