![United-Kingdom Country flag](https://gscalecentral.net/misc/flags/shiny/32/United-Kingdom.png)
you pushed the trains round
Careful!
There is a push option in this new-fangled version of the software!
![Eek! :eek: :eek:](/styles/skype/smiley/emoticon-0104-surprised.gif)
Mmmm - I have done that, and it remains perversely silent
Lone star trains? I had some of these in the early 60s.It's all very complicatedI might go back to the principal behind my very first model railway - before n gauge arrived it was called Treble-0; all diecast, including the track, and you pushed the trains round
From this.....appears the switch and the chuff trigger are connected....
I'm pretty certain that is George Schreyer's working out of the circuit, and on his pages, he mentions that it may not be perfick. However for most of our purposes, it is what it is, and we don't need to know much more.The schematic is laid out a little unusually in that top corner..
I wonder if it is correct?![]()
At the risk of invoking your ire: why are you taking a $1200 loco and putting a $1 sound card in it? Surely a $50 sound card can be justified, and would already have the trigger lead for chuff to directly connect.
Well, good question well presented. I can explain ......................... I think.At the risk of invoking your ire: why are you taking a $1200 loco and putting a $1 sound card in it? Surely a $50 sound card can be justified, and would already have the trigger lead for chuff to directly connect.
Thanks Tony - I've put one in a Bachmann Connie a couple of years ago, and was going by memory, but it may well have been upgraded since then as well.Hey Rhinochugger.
You are wrong about complicated connections on the MyLocosound.
Just hook the chuff wire from the MyLocosound to the chuff trigger connection on the C19 PnP board.
As long as the MyLocosound card ground is connected to the Bachmann pcb ground it will work just fine.
Mmmm - I've never got into track magnets$77 dollars vs $50 on a $1,200 loco for a reasonable sound card... no matter what you paid, it's what it's worth... if you got a Ferrari 1/2 price as a windfall, would you put volkswagen bug tires on it?
In any case, it's going to cost you in parts to try to modify the botchmann sound card to work with the C-19, so maybe the delta is $20 all told... which is now 15 pounds.
and you get bell and whistle with triggers, magnets on your track, which does not take "a lot of track electrics" in fact NO track electrics, just magnets
Where is Peter Lucas now? He piped up on another thread offering his sound card..... Peter??
As per Rhinochugger's suggestion....using a Relay, does overcome the connection problem.
Can be arrangedYes, I likewise considered suggesting a relay, but I have seen them fail, they are not rated for this kind of operation. That said, relatively cheap, but you might research the estimated lifetime of the part, looking for how many cycles it is rated for. You almost surely will get bounce also, but I'm not sure you would hear it.
I think some kind of 555 timer circuit to substitute for the relay and with it's inherent debounce would be what I would use, should someone be holding a gun to my head to make me do this.
