D
Deleted member 4232
Guest
Moved
Ah, my Annie sound board looks a bit different
Yes, I've just posted it aboveBlack wires, shown separately for clarity how both parts are interconnected, and to trace the connections back for fault finding, when satisfied all works, then I'd join all the black GND's together..................
Do you have a picture of the Annie soundboard?
double the benefit!Double post.
Oh, I see .
Yeah, the 9v battery supplies are a PITA - and more so with the Mylocosound card where you use a re-chargeable that is meant to self-trickle charge but always seems to be running out of puffRhino, If I remember correctly, the Annie tender sound board (from all but the new metal geared model) uses a 9v battery power supply that is put into the water filler compartment.
When I replaced all of my Annie sound cards with LGB Uintah/Sumpter mallet boards, I used track power for them and a hall sensor on one of the tender axles for the chuff.
Not sure if this is of any help... apologies if it is a red herring Ian...
EDIT ... apologies mate, you have allowed for the 9v already...message to self .....'DO NOT SKIM READ!'
Yeah, the 9v battery supplies are a PITA - and more so with the Mylocosound card where you use a re-chargeable that is meant to self-trickle charge but always seems to be running out of puff![]()
Even when it's new - a day's running, and it's usually flatThat's 'cos sittin' in da shed, it has gone flat, and as it trickle charges, it needs running for at least half an hour at 3/4 throttle to get anything back into the battery..
Hence do away with it, if possible.. - But does mean no sounds when stationary.
The cap bank still needs a regulator / charger in addition... by that time you can just use the "boost regulator" by itself which is cheaper than the cap bank too.
