Boot Lane Works Nancy
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
www.tumble-down-falls.co.uk
I am building a Boot Lane Nancy, 32mm gauge, the plan is to make it into an Xmas train, so nice lead time. Not going to tell how I built the loco, as that is in the instructions, but I will show the progress, and any issue and thoughts:
I ordered the kit last week 16th (Tuesday), and it arrived the next day, so service and dispatch is great. Looking at the parts which are a mixture of filament and resin printed, and acrylic sheet, they looked well produced, and a quick look through the instructions and they seemed fine - here is what you get, including wheels and motor:
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
Starting the build, my first issue was that there is no information identifying the parts, the very first instruction is to attach the motion bracket to the 2mm acrylic frames, the accompanying photo shows the motion bracket in white, from an end on view, and they were in fact acrylic. Moving forward looking for the frame stretchers, and having built chassis before, the two large item that were the frame stretchers were not what I expected. So a slow start, but I soon had the simple chassis complete:
One point 2 mm screws are used to hold the parts together, and it is suggested that the hole opening is opened slightly with a taper reamers, as the screws form there own threads, I have a 2 mm tap, and found tapping the threads first was a better solution.
Finishing off for the day is adding the wheels:
One final instruction was the motor, which I fitted, and on my 0 Gauge track gave a quick run, the motor is described as 3 - 6 volts, so with 2 AA batteries powered up, and ran quite nicely, so final power will probably be a 3.7 volt Li-Ion battery:
3,553
A little surprised you haven't painted the chassis before fitting the motion and wheels?
I think you will find that you will need to key the surface of the acrylic frames, to get the paint to adhere properly.
Good idea to tap the holes. Should help to give a sturdy build.
I admit to being quite impressed with the Boot Lane offerings..
Will follow this with interest.
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
As it is bolted together, I plan to disassemble to paint, it will not be until it is fully assembled that I will know where (and maybe what) electronics to fit.
3,553
The RCT-MR601 works nicely with a single-cell Lipo.. :blush:
But then I would say that, wouldn't I?
:D
Rhinochugger
Retired Oik
4,254
North West Norfolk
Had a quick look, and Boot Lane say it is inspired by the Rye and Camber Tramway Bagnall loco. Now that was a 3ft gauge operation, so you could run it to scale on 45mm track :D:D - but then it probably wouldn't be so easy to get it round the Crimbo tree :shake::shake:
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
Sadly the turning circle is the same for both 32 and 45 track, and may be to large.
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
So progress, first my comments, on building the body, there are no real instructions, just a list of parts (but not against a drawing), a dry fit is paramount to get things right, and even so mistakes happen, a cut out is already made for the switch which handily is a DPDT Centre off, so a slight change to my wiring, and a hole for the charging port:
Next step (for me) is to add the parts that are screwed to the footplate.
Then build the cab around them, you may notice the charging port has moved!! There are no instructions on what is glued to what, but as the electronics are in the boiler, and the battery in a side tank, nothing is glued to the boiler except the smoke box.
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
With the electronics (Loco Remote Mini B with sound) added, the body is trial fitted on the chassis and tested, though not in this photo a speaker was tested and I was not overly impressed with the sounds, as yet I have not fully planned the lights.
Having the cab mad of clear acrylic does aid in knowing where everything fits.
Next stop the detail!!
5,010
76
I wonder if the speaker will sound better when located wherever in the loco having a sound box? I tend to test the speaker in a plastic box on the bencg to get a better idea of how the sound will be. Hi Fi speakers sound awful outside of their box.
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
Not the speaker, but the sounds themselves, may need to tweak the settings.
1,715
What will you use to stick the clear acrylic?
5,010
76
Oh ok, not used any of the loco remote jobbies. Be interesting to hear what it sounds like when you have tweaked it.
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
E. M. A Plastic weld, it is what was recommended, but it is what I now use anyway, and it works well on both acrylic and the filament 3D print.
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
So a quick update:
Detail assembly was carried out:
Then stripped down for painting, primer and undercoat:
It was at this point that disaster struck, and whilst rubbing back the chassis, I dropped it, and the acrylic side frame broke, though not shattered, I felt that glueing them would not provide the required strength:
After contacting Boot Lane, and initially not receiving a reply, I stripped down the chassis to the constituent parts:
This was with a view to producing my own side frames in brass:
However, Bootlane have now been in touch, and are supplying the replacement parts FOC, so what to do with the frames. As they are only half (or less) the thickness of the acrylic frame my thoughts are to use them outside of the acrylic to provide some additional strength and with them blackened will negate the need to paint the acrylic - thoughts:
3,553
It will add some low-down weight, and of course it will 'look' like metal..
Northsider
3 May 2012
2,431
589
Hertfordshire
That's a good idea. As you have found, acrylic is very brittle and also quite light: a bit of low-down weight will help the loco ride better, too. The areas above the front horn guide and the pony wheel cut-out haven't got much meat to them so reinforcement can only be a good thing. The only complication might be achieving the correct back-to-back measurement on the wheels if the frames are a little bit thicker?
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
I will of course let you all know how it goes, the pros and cons.
justme igor
17 Apr 2020
682
64
Netherlands Westwoud
Netherlands
5,010
76
Ce
rtainly a metal chassis will be mire robust, can it fit inside the frames with a few mods? Then no issues about painting, brass is notoriously tricky to keep painted unless you used self etching primer.
