Jon the frames are chemically blackened.Ce
rtainly a metal chassis will be mire robust, can it fit inside the frames with a few mods? Then no issues about painting, brass is notoriously tricky to keep painted unless you used self etching primer.
Yep, the penny has just dropped. I thought acrylic was meant to be like Lexan - virtually unbreakable.Following the build with interest. It seems surprising the frames are acrylic if they can break by just being dropped. Sounds like a good idea to reinforce with brass, provided there's enough clearance for the back to backs.
Rik
I am, thank you.You may be confusing acrylic, with polycarbonate?
The latter is used (amongst other things) for roofing panels and riot shields..
Acrylic is used in these models, because it can be laser-cut 'easily', and the by-products are less dangerous..
That's why this forum is so good, people share their problems, so the rest can try and avoid doing the sameGood lesson learnt -
... but some of us do it anywayThat's why this forum is so good, people share their problems, so the rest can try and avoid doing the same
that is called: old enough to know better but young enough to do it anyway........ but some of us do it anyway
Now, now, mustn't be crossI think I may have bought hex-head screws? - These 'giant' cross-head fixings, just annoy me!
I painted mine, from a normal viewing distance, they look OKI think I may have bought hex-head screws? - These 'giant' cross-head fixings, just annoy me!
With the body work fitted hopefully they will not be seen.I think I may have bought hex-head screws? - These 'giant' cross-head fixings, just annoy me!
Error corrected, dyslexia rules KO!Beautifully done, Jim.
I'm intrigued as to you getting "the elections in place". A reference to Putin or Trump, maybe? I can't figure out what your predictive text or spell checker was fooled by
