Zerogee said:Thanks for the great write-up, Cliff!
bunnyrabbit03 said:I have actually used a Dietz micro xs sound module via SUSI in combination with a Zimo decoder on analogue for test purposes. It works, you just have to 'tell' the decoder what functions to activate in analogue, e.g. steam sound. As far as I know, you can also use a Zimo decoder with a power buffer connected on analogue; maybe Cliff knows if this also works with the Lenz Power 3 modules?
bunnyrabbit03 said:..... maybe Cliff knows if this also works with the Lenz Power 3 modules?
Cliff George said:bunnyrabbit03 said:..... maybe Cliff knows if this also works with the Lenz Power 3 modules?
Well I almost never run on analogue so I did some experiments. A loco with a Gold Maxi and Power 3 buffer does work on analogue. That was a surprise to me, I must have read too many Massoth manuals!
As Jon said the SUSI connected sound unit did not make any sounds. I would have thought that it was a function of the decoder, not the SUSI sound unit if it works or not in analogue. Send it the correct things and it will work.
