The switch in the LGB tram looking through the front window.If a 'toggle' switch, then not original..
*Though I stand to be corrected.
A slide-switch (or possibly two) would be a different story..
No-way, that is an OEM switch..The switch in the LGB tram looking through the front window.
Meaning it is an OEM switch or "No-way that is an OEM switch" meaning it is not an OEM switch? (commas matter) I'm not familiar enough with LGB stock to have an opinion one way or the other.No-way, that is an OEM switch..
Interesting..
please advise what the toggle switch inside the body is for?
I think you may be being a bit unfair on LGB, they build their stuff for robustness, which is why they are such a popular product for starting out with, so details sometimes take the back seat. Plus of course any details you want to add would probably be superior to what they would provide.can now satisfy myself that unless another LGB tram came up for sale equally cheaply I have zero interest in getting another. The model is about as basic as it can get and needs a fair bit of detailing work.
A fair bit more of the underside which protrudes into the interior of the tram will be removed before I'm finished, I just need to see where and how the batteries will be fitted, along with a few more things.Definitely not original, so anybody's guess unless the destination of the wires tells the story.
I see you bought it off ebay from Footplate Trains. One of the photos on the listing shows the underside of that switch (and much butchery of plastic - maybe to fit a non-LGB motor block?) . . .
. . . whereas it should l;ok more like this . . .
The switch looks to have been installed where there was originally a curved slot . .
. . . that (with a rotary switch?) allowed the power to be taken only from the rails (standard two-rail operation), or from the catenary (with both rails as the common return?). Maybe the switch was installed for the same purpose on a different motor block.
Best wishes
In my defence I did say they are models to be seen operating from a distance, aye they are robust looking models with potential to build in to a more detailed model, and yes they would make a good starting model for someone just getting in to tramway modelling.I think you may be being a bit unfair on LGB, they build their stuff for robustness, which is why they are such a popular product for starting out with, so details sometimes take the back seat. Plus of course any details you want to add would probably be superior to what they would provide.
Can anyone suggest how I remove the roof from the LGB tram, I need to get inside to fit a new floor at some point.
I purchased my first Bachmann tram just to have something to run and experiment with while I built my own models of the Isle of Man and Rothesay, with no intention to buy any further ready to run models.Good morning David,
this morning I got a message from ebahh that I had watched a lgb tram, it was the one I see here in the forum now.
Here are a few pictures of how you can open the tram. When you opend the upper roof section, than push the side windows a bit outside, The lower roof is now ready to take away For working on the frame I think it is easier to remove the frame. It is fixed with four screws at the edges of the body. The screws fit inside the body into the seats. So it hold the body as well to the frame.
By the way.
I once had a Bachmann tram. Its running characteristics were very, very bad. In addition, this the really fit in with the look of trams in Germany. So I used a few small parts for conversions. Then it lay unused in the corner for more than 10 years. At some point someone from England was looking for such a wreck for his own conversion. So it found a new purpose. From 1987 I had two LGb tram trains. I quickly rebuilt one train in an amateurish way. It still runs today, but had to be adapted again. Then I started to collect these trams. I have almost all of them. They also went to exhibitions. Again and again I was able to buy very inexpensive LGB trams. A trailer like that cost about 40.00 euros. With a motor it cost a maximum of 75,00 Euro. Unimaginable today. I then converted these into work wagons. I still have 10 complete tram bodies here for conversion. I will probably sell them. At some point I got a kit for a completely different tram. Since then, I only build prototypical trams. In the meantime, I have so many self-built trams that the original LGB trams are no longer needed. I want to buy an e-bike with them or may be I should have other kits made....
Their is nothing wrong with a tramway focusI got pratty obsessed with trams at one stage and likeschienenkönig started to collect the regular range LGB ones. That stupidity stopped when LGB introduced the hideously coloured Pink one. As has been said the LGB ones are good runners basically having a standard LGB block. I did get a few Bachman ones and the quality of running with them is best not mentioned. In my view they are better converted to Battery Operation, however here can also be pitfalls as they do not seam to work so well with Crest RX, I had a couple of the chassis in my RhB box motor and they would not run at all without horrible jerkiness, but with normal DC uncontrolled battery power they ran smooth. Said conversion was converted to a couple of US motor blocks and now runs just fine.
Lucky lucky, the Melbourne traction motors are a perfect fit for the LGB tram, and it looks like I'll be able to fit some batteries under the longitudinal seats once I cut away the protrusion in to the interior.
What has surprised me with the LGB model is the fact it seems to have an internal sliding block which takes the axles, the great thing about this is that I won't need to build a new truck for this model, I haven't tried it yet, but I'm hoping the fitting of axle bearings will avoid the need for new axles a well.Good to see it works for this application. I think a lot of the more financially well off people in this hobby have a big blind spot for cost effective solutions to these type of problems.
Thank you for letting us know about this model, just trying to see how I can bid and if the seller will send to Scotland, which I'll do when I get the computer out tomorrow, thanks.I don't know where to post this offer on Ebahh to post. Since some people here enjoy the Bachmann trams, I'll put this link here. I would like to emphasis. Petere here that I am neither the seller nor do I know him.
But I think the photos alone are worth seeing. Perhaps they will serve as an inspiration.
Peter
Straßenbahn 1:22,5 Bachmann Liliput LGB Spur G Custom Unikat
Seller's item description
Tram 1:22.5 by Bachmann Custom unique without original packaging.
The offer is made as used because the tram was repainted and partly rebuilt. The train was never used by me and was only on the shelf and is therefore a bit dusty. The track was rebuilt and repainted by the previous owner. Notable here are the paintwork and lettering, the clad platforms, the scissor pantograph and the line/goal indicator, which is movable. 4 different destinations and 2 different line numbers can be displayed. The photos are part of this auction. Only the item named in the title is offered without any frills.
The shipment is well packaged exclusively as an insured DHL package about 1 week after receipt of payment. On express request, it can also be sent as a DHL parcel - the buyer then assumes the risk. Payment is made in advance via PayPal or bank transfer.
This auction is private and there is no right to exchange or return.
Anyone with the above If you do not agree with the terms, please do not bid.
And now have fun!
