Going nuts...
Well the job is done.
I can confirm that an external M2 thread can be cut effectively onto 2 mm brass rod.
Consider the shrew screw well and truly tamed.
Now to work out how to obtain a nice tight 90 degree angle.
Hey ho...
Once more unto the breach...
Regards,
Paul.
All's Well That Ends Well
Hey ho...
Regards,
Paul.
Presumably you now wish to bend the item? A source of heat would ensure the job is done without breaking the rod. Google ‘bending a rod’ and include the name of whatever type of metal it is.
Brass sometimes goes 'short' (and will snap) when heated; but sometimes doesn't. Depends on the zinc content, I think.
If you need to anneal brass, it needs heating up and then quenching. However, as Northsider says, there's no guarantee.
That is as may be, so what is his option for bending the Brass that he is using?
I've never done it, but a quick trawl of the internet suggests heat to dull red and then quench in water. Although I would think 2mm diameter rod might bend without annealing -brazing rod certainly will.
It will bend cold but the radius of the bend is a bit too big even using my round / half round pliers. Looks like red heat may be the answer.
