Thanks Phil. Ah but I am not that Electrically Literate to make the connection with the Circular bit in the pic and the circuit diagram. Thus my query. As they say you do not know what you do not know!No connection..
Compare it with the diagram in Post #7..
No join in the middle of the "string" of 4 diodes Jon, just close in the picture.Greg that looks interesting I could even make one of them, presume the Bridge Rectifier is the round blob with 524 on it. Also where the Middle Lower Wire comes out of it is there a join to the centre of the 4 Diodes or should it be isolated. That is not too clear from the Picture.
You can drive two points, from one channel, if you have a loop arrangement that you want BOTH ends to be one-or-the-other, at the same time.Do the LGB Turnouts need to be adjusted for DCC run other than connecting to a decoder?
This may help to get your Right Hand Loop a little bit longer. Also be very careful not to try any Crossovers at the Top near the Planting as you would in efffect create a Reverse Loop with all the Problems that would entail.Guys,
I included a picture of my plans for my garden layout. I would like to get some critique from you guys and also some tips of do's and don'ts. Im also now having doubts on using the Piko Smart Control at 5 amps. Im not sure if it can handle this large of a layout. Ive looked into the ESU Cab Control which is similar to the Piko Smart Control but at 7 amps. I might have to go back to the drawing board on choosing a DCC system. Id like to stay under $500 if possible.
Im very new to this so I'd need some advice how to wire everything up. It seems to me it will be daunting, so im kind of worried, and might just scrap the whole thing. I have 80% of the tracks and Id like to run a Harz style era scenery/trains.
On the bottom left of the layout I was at first thinking of using LGB R2 (1646mm) Diameter, but saw that Piko had a slightly larger Diameter Track G-R3 (920mm Radius) so am going to use that since don't want to use the LGB R3 (2486mm Diameter) which will cut into my grass area by a lot.
Thanks in advance
I agree withPhilP about the passing loops, as long as you are happy for trains to always use the right hand track then you can use the manual point switches to act as a real-life "sprung point" to save yourself the expense of motors and the tedium of wiring. The more you can use sprung points the better (cheaper, less wiring, less maintenance)
Make sure you Install additional track connections, that way any problems with poor rail joints will be minimised,
You only have one "S" curve, where you immediately go from a curve in one direction to a curve in the opposite direction. It's in the bottom left curve on the "inside" track. ease that curve a bit, get a piece of straight for transition, and eliminate the straight before the switch.
if you like the Harz you may like to look at my Vid and Line Build linked below. I am into the Harz Lines, Selktalbahn being my chosen route.
There is no reason to not have reversing loops, it is a simple process, with a few insulators and a "black box". Being free of the constraints of simple DC layout design is one of the advantages of DCC.
Reversing loops are not complicated, especially if you use the "short sensing" methodology, instead of adding all the complexity of the isolating sections and relays and complications the Massoth and similar units demand.
I've been using a LGB 55085 Reverse Loop Module (which is identical to the Massoth 8157001 Reverse loop Module in everything except color) on my outdoor RR for three years now. It works perfectly and without any problems. There are no additional relays required - just the module itself (which does indeed have a couple of internal relays). Yes, using the sensors track segments rather than short circuit sensing does involve some additional wiring. And, some thought and careful following of instructions is required to make sure the sensor segments are wired correctly. But, once installed, it works just fine with no operator intervention required. And, if desired, an internal jumper can be changed to make the module short circuit sensing too which eliminates the need for the sensor tracks. The module is weather resistant (not weather-proof) and designed for use outdoors. Mine resides in a Polo trackside building year-around along with a 4 channel DCC switch decoder that controls routing through my wye. The building protects the module from direct exposure to rain and snow. If you're interested check out my "Phil S' RR" thread under the "Large Scale Pictures" heading on this site.Reversing loops are not complicated, especially if you use the "short sensing" methodology, instead of adding all the complexity of the isolating sections and relays and complications the Massoth and similar units demand.
I have been involved with the running of a Line using LGB then Massoth Reverse Loop over quite a few Years. No problems or damage were endured by any of the Locomotives used on the Line and there were a lot of different and expensive LGB Locomotives involved.I've been using a LGB 55085 Reverse Loop Module (which is identical to the Massoth 8157001 Reverse loop Module in everything except color) on my outdoor RR for three years now. It works perfectly and without any problems. There are no additional relays required - just the module itself (which does indeed have a couple of internal relays). Yes, using the sensors track segments rather than short circuit sensing does involve some additional wiring. And, some thought and careful following of instructions is required to make sure the sensor segments are wired correctly. But, once installed, it works just fine with no operator intervention required. And, if desired, an internal jumper can be changed to make the module short circuit sensing too which eliminates the need for the sensor tracks. The module is weather resistant (not weather-proof) and designed for use outdoors. Mine resides in a Polo trackside building year-around along with a 4 channel DCC switch decoder that controls routing through my wye. The building protects the module from direct exposure to rain and snow. If you're interested check out my "Phil S' RR" thread under the "Large Scale Pictures" heading on this site.
I've read the PSX-AR manual. I like the fact that it is all solid state. It also has provision for additional operating possibilities (and wiring complexity!) It is less expensive at one-half to two-thirds the cost of the Massoth or LGB modules. But, it will require a weather-proof enclosure to make sure it is adequately protected when used in the outdoors.
Finally, I may be paranoid, and my concern may be completely un-warranted but I just don't like the idea of using my expensive locomotives as a short circuit to cause the polarity of my reverse loop (mine's actually a wye) to change over.
Never had a problem with Lenz reverse loop devices (work by detecting a short). The time it takes to detect the short and switch polarity is very short.I've been using a LGB 55085 Reverse Loop Module (which is identical to the Massoth 8157001 Reverse loop Module in everything except color) on my outdoor RR for three years now. It works perfectly and without any problems. There are no additional relays required - just the module itself (which does indeed have a couple of internal relays). Yes, using the sensors track segments rather than short circuit sensing does involve some additional wiring. And, some thought and careful following of instructions is required to make sure the sensor segments are wired correctly. But, once installed, it works just fine with no operator intervention required. And, if desired, an internal jumper can be changed to make the module short circuit sensing too which eliminates the need for the sensor tracks. The module is weather resistant (not weather-proof) and designed for use outdoors. Mine resides in a Polo trackside building year-around along with a 4 channel DCC switch decoder that controls routing through my wye. The building protects the module from direct exposure to rain and snow. If you're interested check out my "Phil S' RR" thread under the "Large Scale Pictures" heading on this site.
Forgot to mention. I never leave electronics outside wired to the track. One lightning strike is all it takes, even if it is a couple of hundred metres away. I lost a Lenz device and a TV with such a strike. All of my DCC stuff is in the shed and I disconnect turnouts and air gap the track when not in use.Never had a problem with Lenz reverse loop devices (work by detecting a short). The time it takes to detect the short and switch polarity is very short.
Geoff
Geoff, valid point, I lost a router, video player (a while ago) and blew the TV fuses in a lightening storm, never considered disconnecting my devices TE and ancillary drivers, I assume a strike will take it all out - never happen with battery powerForgot to mention. I never leave electronics outside wired to the track. One lightning strike is all it takes, even if it is a couple of hundred metres away. I lost a Lenz device and a TV with such a strike. All of my DCC stuff is in the shed and I disconnect turnouts and air gap the track when not in use.
Geoff
