Paul2727
Hi Dan,
It's always useful to post a photo of the underside of a loco when asking questions about it.
The model number and stickers give a lot of info, this is particularly useful with models that have been in production for a while.
Underneath there should be a gold sticker. This will tell you the age of the loco.
2nd & 3rd number = day
4th & 5th = month
1st & 6th = year.
Example: 014054 is 14th may 2004
There may be another sticker or marking too.
The marking (1) and stickers (2-5) displayed below are usually found of the bottom of LGB® locomotives that were manufactured before 2006; they are used to indicate the DCC (MTS) status of a locomotive.
Locomotives manufactured after 2006 do not usually bear stickers indicating their DCC (MTS) status; the information may be available in the user's manual or on LGB's website.
An LGB® locomotive with an engraved "D" on the bottom side of the gearbox is suitable for DCC (MTS); the "D" marking indicates that the gearbox is a 4-pin gearbox with a motor that is electrically isolated from the track. A gearbox Without the "D" marking may have to be converted to a 4-lead gearbox to become suitable for DCC (MTS).
An LGB® locomotive without one of the 4 stickers "2-5" is either manufactured after 2006, or missing its sticker, or pre-DCC (MTS). The locomotive may require disassembly to determine its DCC(MTS) status; pre-DCC locomotives should have their basic electronics removed for conversion to DCC.
Sticker "2" indicates that an LGB® locomotive is DCC ready and equipped with a 6-pole decoder interface. An interface cable (Massoth 6-pin Interface cable, item # 8312061) is required to connect a decoder to the locomotive's PCB board. The 6-pin decoder interface is plug-and-play compatible with the LGB® 55021 decoder, the Massoth eMOTION L decoder, the Massoth eMOTION XL decoder, and the Massoth eMOTION XLS sound decoder.
Sticker "3" indicates that an LGB® locomotive is DCC ready and equipped with a 10-pin direct decoder interface plug-and-play compatible with the LGB® 55021 decoder, the Massoth eMOTION L decoder, the Massoth eMOTION XL decoder, and the Massoth eMOTION XLS sound decoder.
Sticker "4" indicates that an LGB® locomotive is DCC ready and equipped with an onboard-decoder that is suitable for both digital and analog operation. The Massoth S sound module is perfectly suitable for adding sound to LGB® locomotives equipped with an onboard-decoder.
Sticker "5" indicates that an LGB® locomotive is DCC ready and equipped with the new 10-pin DCC interface plug-and-play compatible with the LGB® 55027 MTSIII decoder, the Massoth eMOTION XL decoder, and the Massoth eMOTION XLS sound decoder.
In 2014 LGB introduced a new 28-pin decoder interface which they represented in their literature by symbol "6". The interface, sometimes referred to as the LGB/Märklin Gauge 1 interface, is plug-and-play
Regards,
Paul.
4th & 5th = month
1st & 6th = year.
Regards,
Paul.
