I was under the impression there was only the one run of these (in the various liveries). I wasn't aware of any production differences such as the wheel mounting that you mentioned (though I've read about such changes in other Aristo models over the years). Where have you read about such differences with regard to the 66 (just out of interest)?
[edit] Ah - are you thinking that the sintered D-hub wheel changes that happened to the SD45 motor blocks also happened to the 66? I've never seen that applied to any 66, I thought the 66s were all made a long time before the 2012 SD45 run (as documented on Greg Elmasian's pages)[/edit]
There seem to be two different types as the front set up is different regards the coupling , light set up(type) and the lashing rings
I put this down to the model mimicking the real life prototype, rather than just differing model production runs?? - I do not know enough about the '66 and its' variants to 'rivet count' this.
My main interest in the '66 is as the only (that I know of) RTR 'British' outline diesel no the market. - At this scale, and price.
Anything else 'G1' and British outline, comes as a set of parts.. Normally in brass.. Hence at a low-volume premium, and with a high probability of never getting to run and (in my case) possibly looking a bit naff.
Surely that's just detailing, not a fundamentally different production run? I have the german HGK version, I believe it has suitably different lighting patterns compared to the british livery models.
The motor blocks used are the same as my SD45.
All aristo ones are the 4 door body, later class 66`s ala "Evening Star) are 5 door bodies
Lol, , I was talking to someone about doing the evening star version , and that's exactly what he told me
The biggest difference on the 5 door ones is the much smaller fuel tank to keep the axle loading within spec.All aristo ones are the 4 door body, later class 66`s ala "Evening Star) are 5 door bodies
There's also other differences like.....
Much bigger radiator grilles.
Two piece side windows - instead of three piece with quarter light.
Darkened glass.
Wing mirrors.
Frame mounted sand boxes.
Mini plough.
Swing buckeye couplers.
etc. etc.
